Datasheet Wago 805-370 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 20-полюсный; Зажим Push-in CAGE CLAMP
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 13.6 mm / 0.535 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| GTIN | 4055143388214 |
| Height | 13.7 mm / 0.539 inch |
| Height from the surface | 10.5 mm / 0.413 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 20 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Rated current | 17.5 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 3.2 мм |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 20 |
| Total number of potentials | 20 |
| Вес | 9.37 г |
| Ширина | 71.5 mm / 2.815 inch |
Серия: 805 (100 из 104)
- 805-106 805-106/000-006 805-107 805-108 805-109 805-110 805-111 805-112 805-113 805-114 805-115 805-116 805-117 805-118 805-119 805-120 805-121 805-122 805-123 805-124 805-152 805-153 805-154 805-155 805-156 805-157 805-158 805-159 805-160 805-161 805-162 805-163 805-164 805-165 805-166 805-167 805-168 805-169 805-170 805-171 805-172 805-173 805-174 805-302 805-302/200-604 805-303 805-303/200-604 805-304 805-304/200-604 805-305 805-305/200-604 805-306 805-306/200-604 805-306/200-604/997-406 805-307 805-307/200-604 805-307/200-604/997-406 805-308 805-308/000-023 805-308/200-604 805-308/200-604/997-406 805-309 805-310 805-311 805-312 805-313 805-314 805-315 805-316 805-317 805-318 805-319 805-320 805-321 805-322 805-323 805-324 805-352 805-353 805-354 805-355 805-356 805-357 805-358 805-359 805-360 805-361 805-362 805-363 805-364 805-365 805-366 805-367 805-368 805-369 805-370 805-371 805-372 805-373 805-374
- PCB Interconnect
