Datasheet Wago 806 — Даташит
Производитель | Wago |
Серия | 806 |
![]() 13 предложений от 13 поставщиков Ленточные и Плоские Кабели, Flat Cable 25Conductors 28AWG 30.48m Tinned Copper Gray/Red Edge 300V Roll | |||
80-6102-0196-6 3M | 2 173 ₽ | ||
80-6102-0185-9 | по запросу | ||
80-6102-0133-9 | по запросу | ||
806-102 Wago | по запросу |
Parameters / Models | 806-102![]() | 806-103![]() | 806-104![]() | 806-105![]() | 806-106![]() | 806-107![]() | 806-108![]() | 806-109![]() | 806-110![]() | 806-111![]() | 806-112![]() | 806-202![]() | 806-203![]() | 806-204![]() | 806-205![]() | 806-206![]() | 806-207![]() | 806-208![]() | 806-209![]() | 806-210![]() | 806-211![]() | 806-212![]() | 806-902![]() | 806-903![]() | 806-904![]() | 806-905![]() | 806-906![]() | 806-907![]() | 806-908![]() | 806-909![]() | 806-910![]() | 806-911![]() | 806-912![]() |
Actuation type | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | |||||||||||
Clamping spring material | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | |||||||||||
Цвет | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | |||||||||||
Conductor entry angle to the PCB, ° | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | |||||||||||
Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | |||||||||||
Connector connection type | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs | for PCBs |
Contact material | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | |||||||||||
Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | |||||||||||
Contact type (pluggable connector) | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Female connector/socket | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug | Male connector/plug |
Country of origin | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | PL | DE | CN | DE | DE | DE | DE | DE | DE | DE | DE | DE |
Габариты: глубина | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 19.8 mm / 0.78 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch | 2.7 mm / 0.106 inch |
Drilled hole diameter (tolerance), мм | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | 1.3(+ 0.05) | ||||||||||||||||||||||
Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | |||||||||||
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | |||||||||||
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | 0.25 … 1 mm² | |||||||||||
Fire load, MJ | 0.056 | 0.08 | 0.104 | 0.128 | 0.152 | 0.176 | 0.2 | 0.224 | 0.248 | 0.272 | 0.296 | 0.059 | 0.083 | 0.107 | 0.131 | 0.155 | 0.179 | 0.203 | 0.227 | 0.251 | 0.275 | 0.299 | |||||||||||
Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | |||||||||||
GTIN | 4045454076900 | 4045454076917 | 4045454076924 | 4045454076931 | 4045454076948 | 4045454076955 | 4045454076962 | 4045454076993 | 4045454077006 | 4045454077037 | 4045454077044 | 4045454077068 | 4045454077075 | 4045454077099 | 4045454077105 | 4045454077112 | 4045454077136 | 4045454077143 | 4045454077174 | 4045454077181 | 4045454077198 | 4045454077204 | 4044918368117 | 4044918325813 | 4044918325837 | 4044918325882 | 4044918325820 | 4044918429191 | 4044918368124 | 4044918429221 | 4044918429238 | 4044918429245 | 4044918429252 |
Height | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 16.25 mm / 0.64 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 23.3 mm / 0.917 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch |
Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | |||||||||||
Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | |||||||||||
Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | |||||||||||
Material group | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | |||||||||||
Mating direction to the PCB, ° | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | |||||||||||
Number of Poles | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Number of connection types | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |||||||||||
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
PCB contact | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT |
Pin spacing | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch |
Product Group | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) |
Rated current, A | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | |||||||||||
Rated impulse voltage (II / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |||||||||||
Rated impulse voltage (III / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |||||||||||
Rated impulse voltage (III / 3), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |||||||||||
Rated voltage (II / 2), В | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | |||||||||||
Rated voltage (III / 2), В | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | |||||||||||
Rated voltage (III / 3), В | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | |||||||||||
Solder pin diameter, мм | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Solder pin length, мм | 3.4 | 3.4 | 3.4 | 3.4 | 3.4 | 3.4 | 3.4 | 3.4 | 3.4 | 3.4 | 3.4 | ||||||||||||||||||||||
Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | 0.2 … 1.5 mm² / 24 … 16 AWG | |||||||||||
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | 9 … 10 mm / 0.35 … 0.39 Inch | |||||||||||
Total number of connection points | 4 | 6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 | 22 | 24 | 4 | 6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 | 22 | 24 | |||||||||||
Total number of potentials | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | |||||||||||
Вес, г | 2.728 | 3.959 | 5.19 | 6.421 | 7.652 | 8.883 | 10.114 | 11.345 | 12.576 | 13.807 | 15.038 | 2.826 | 4.057 | 5.288 | 6.519 | 7.75 | 8.981 | 10.212 | 11.443 | 12.674 | 13.91 | 15.141 | 0.28 | 2.514 | 0.55 | 0.68 | 0.7 | 0.935 | 1.1 | 1.2 | 1.4 | 9.218 | 1.7 |
Ширина | 11.5 mm / 0.453 inch | 16.5 mm / 0.65 inch | 21.5 mm / 0.846 inch | 26.5 mm / 1.043 inch | 31.5 mm / 1.24 inch | 36.5 mm / 1.437 inch | 41.5 mm / 1.634 inch | 46.5 mm / 1.831 inch | 51.5 mm / 2.028 inch | 56.5 mm / 2.224 inch | 61.5 mm / 2.421 inch | 11.5 mm / 0.453 inch | 16.5 mm / 0.65 inch | 21.5 mm / 0.846 inch | 26.5 mm / 1.043 inch | 31.5 mm / 1.24 inch | 36.5 mm / 1.437 inch | 41.5 mm / 1.634 inch | 46.5 mm / 1.831 inch | 51.5 mm / 2.028 inch | 56.5 mm / 2.224 inch | 61.5 mm / 2.421 inch | 9.8 mm / 0.386 inch | 14.8 mm / 0.583 inch | 19.8 mm / 0.78 inch | 24.8 mm / 0.976 inch | 29.8 mm / 1.173 inch | 34.8 mm / 1.37 inch | 39.8 mm / 1.567 inch | 44.8 mm / 1.764 inch | 49.8 mm / 1.961 inch | 54.8 mm / 2.157 inch | 59.8 mm / 2.354 inch |
Серия: 806 (33)
