Datasheet Wago 806-109 — Даташит
2-проводные клеммы для печатных плат; 1,5; Шаг контактов 5 мм; 9-пол.; Push-in CAGE CLAMP
806109-SF TE Connectivity | от 46 171 ₽ | ||
80-6109-0939-4 | по запросу | ||
80-6109-1210-9 | по запросу | ||
80-6109-4505-9 | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 19.8 mm / 0.78 inch |
Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
Fire load | 0.224 MJ |
GTIN | 4045454076993 |
Height | 16.25 mm / 0.64 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Number of Poles | 9 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 10 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin diameter | 1 мм |
Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 18 |
Total number of potentials | 9 |
Вес | 11.345 г |
Ширина | 46.5 mm / 1.831 inch |
Серия: 806 (33)
