Datasheet Wago 806-111 — Даташит
Серия806
Модель806-111
2-проводные клеммы для печатных плат; 1,5; Шаг контактов 5 мм; 11-пол.; Push-in CAGE CLAMP
Wago 806-111
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact materialCopper alloy
Contact platingtin-plated
Country of originPL
Габариты: глубина19.8 mm / 0.78 inch
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1 mm²
Fire load0.272 MJ
GTIN4045454077037
Height16.25 mm / 0.64 inch
Material groupI
Number of Poles11
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing5 mm (0.197 inch)
Rated current10 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)250 В
Solder pin diameter1 мм
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points22
Total number of potentials11
Вес13.807 г
Ширина56.5 mm / 2.224 inch
На английском языке: Datasheet Wago 806-111
