Datasheet Wago 806-204 — Даташит
2-проводные клеммы для печатных плат; 1,5; Шаг контактов 5 мм; 4-пол.; Push-in CAGE CLAMP
2-CONDUCTOR PCB TERMINAL BLOCK; | |||
| 806-204 Wago | по запросу | ||
| GO-806-204 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 19.8 mm / 0.78 inch |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| Fire load | 0.107 MJ |
| GTIN | 4045454077099 |
| Height | 23.3 mm / 0.917 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin diameter | 1 мм |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 8 |
| Total number of potentials | 4 |
| Вес | 5.288 г |
| Ширина | 21.5 mm / 0.846 inch |
Серия: 806 (33)
