Datasheet Wago 816 — Даташит
Серия816
Datasheet Wago 816
12 предложений от 6 поставщиков
Инструмент: для опрессовки; неизолированные коннекторы
TE Connectivity
2 239 ₽
Зенер
Россия и страны ТС
NB-8161-02
от 5 264 ₽
NB-8161-02
от 5 298 ₽
816102
Filtran
Parameters / Models816-102
816-102
816-103
816-103
816-104
816-104
816-105
816-105
816-106
816-106
816-107
816-107
816-108
816-108
816-109
816-109
816-110
816-110
816-111
816-111
816-112
816-112
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветgraygraygraygraygraygraygraygraygraygraygray
Conductor entry angle to the PCB, °4545454545454545454545
Connection technologyPush-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Contact materialCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloy
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originCHCHCHCHCHCHCHCHCHCHCH
Габариты: глубина17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch17 mm / 0.669 inch
Drilled hole diameter (tolerance), мм1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)1.1(+ 0.1)
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²0.2 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²0.2 … 1.5 mm²
Fire load, MJ0.0520.0740.0960.1180.140.1620.1840.2060.2280.250.272
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0
GTIN40454547320594045454732066404545473209740454547321104045454732127404545473214140454547321654045454732196404545473220240454547322264045454732233
Height20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch20.1 mm / 0.791 inch
Height from the surface16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch16.6 mm / 0.654 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C
Material groupIIIIIIIIIII
Number of Poles23456789101112
Number of connection types11111111111
Number of levels22222222222
Number of solder pins per potential11111111111
PCB contactTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHT
Pin spacing5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)
Product Group4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)
Rated current, A1414141414141414141414
Rated impulse voltage (II / 2), kV44444444444
Rated impulse voltage (III / 2), kV44444444444
Rated impulse voltage (III / 3), kV44444444444
Rated voltage (II / 2), В630630630630630630630630630630630
Rated voltage (III / 2), В320320320320320320320320320320320
Rated voltage (III / 3), В320320320320320320320320320320320
Solder pin arrangementover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in line
Solder pin dimensions0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm0.8 x 0.5 mm
Solder pin length, мм3.53.53.53.53.53.53.53.53.53.53.5
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG0.2 … 1.5 mm² / 24 … 16 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points4681012141618202224
Total number of potentials23456789101112
Вес, г2.5863.754.9146.0787.2428.4069.5710.73411.89813.06214.226
Ширина11.5 mm / 0.453 inch16.5 mm / 0.65 inch21.5 mm / 0.846 inch26.5 mm / 1.043 inch31.5 mm / 1.24 inch36.5 mm / 1.437 inch41.5 mm / 1.634 inch46.5 mm / 1.831 inch51.5 mm / 2.028 inch56.5 mm / 2.224 inch61.5 mm / 2.421 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 816
