Datasheet Wago 826-166 — Даташит
Клеммная колодка для сквозного монтажа; с торцевой пластиной и фиксирующим зажимом; 6-полюсная; для пластин толщиной 1-4 мм; ширина 7 мм; серая
5 предложений от 5 поставщиков РЧ-соединители N ST PLUG RG8/213 UG-21B/U  | |||
| 3-826166-2 TE Connectivity  | 678 ₽ | ||
| 82-6166 Amphenol RF  | по запросу | ||
| 826166-6 Filtran  | по запросу | ||
| 3-826166-2MODU2F2X3 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | DE |
| Габариты: глубина | 42.5 mm / 1.673 inch |
| Fine-stranded conductor | 0.08 … 4 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 2.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.638 MJ |
| GTIN | 4044918532785 |
| Height | 23.55 mm / 0.927 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Mounting type | Locking claw |
| Number of Poles | 6 |
| Number of connection types | 2 |
| Number of levels | 1 |
| Pin spacing | 7 mm (0.276 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 32 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Ratings note | Suitable for neutral-grounded, three-phase, 4-wire systems rated at 400 V (line-to-line) per IEC/EN 60664-1. |
| Solid conductor | 0.08 … 4 mm² / 28 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 6 |
| Type of mounting | Feed-through mounting |
| Вес | 35.064 г |
| Ширина | 43.5 mm / 1.713 inch |
Серия: 826 (26)
- PCB Interconnect
