Datasheet Wago 826-171 — Даташит
Клеммная колодка для сквозного монтажа; с торцевой пластиной и фиксирующим зажимом; 11-полюсная; для пластин толщиной 1-4 мм; ширина 7 мм; серая
![]() 18 предложений от 9 поставщиков Кнопочный Давления, Push Button Switch, IK10, IP65, IP67, 22 (Dia.)mm, SPDT-NO/NC, Panel Mount, Momentary, 240V AC-DC | |||
82-6171.1000 | 1 271 ₽ | ||
82-6171.2000 | от 2 846 ₽ | ||
826-171 | по запросу |
Цвет | gray |
Country of origin | DE |
Габариты: глубина | 42.5 mm / 1.673 inch |
Fine-stranded conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 2.5 mm² |
Fire load | 1.15 MJ |
GTIN | 4044918532853 |
Height | 23.55 mm / 0.927 inch |
Material group | I |
Mounting type | Locking claw |
Number of Poles | 11 |
Number of connection types | 2 |
Number of levels | 1 |
Pin spacing | 7 mm (0.276 inch) |
Rated current | 32 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Ratings note | Suitable for neutral-grounded, three-phase, 4-wire systems rated at 400 V (line-to-line) per IEC/EN 60664-1. |
Solid conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 22 |
Total number of potentials | 11 |
Type of mounting | Feed-through mounting |
Вес | 59.361 г |
Ширина | 78.5 mm / 3.091 inch |
Серия: 826 (26)
- PCB Interconnect
