Datasheet Wago 831-3102/133-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Зажимная планка; 10 мм²; Шаг контактов 7,62 мм; 2-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 831-3102/133-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 41.9 mm / 1.65 inch |
| Fine-stranded conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 6 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 6 mm² |
| GTIN | 4055143492805 |
| Height | 27.5 mm / 1.083 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Material of the additional spring for socket contact | Chrome nickel spring steel (CrNi) |
| Mismating protection | Yes |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.62 mm (0.3 inch) |
| Rated current | 41 A |
| Rated impulse voltage (II / 2) | 8 kV |
| Rated impulse voltage (III / 2) | 8 kV |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 1000 В |
| Rated voltage (III / 3) | 800 В |
| Solid conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Strip length | 13 … 15 mm / 0.51 … 0.59 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Вес | 16.77 г |
| Ширина | 17.12 mm / 0.674 inch |
Серия: 831 (100 из 103)
- 831-137 831-3102 831-3102/000-9037 831-3102/037-000 831-3102/037-9037 831-3102/133-000 831-3103 831-3103/000-9037 831-3103/037-000 831-3103/037-9037 831-3103/133-000 831-3104 831-3104/000-9037 831-3104/037-000 831-3104/037-9037 831-3104/135-000 831-3105 831-3105/000-9035 831-3105/000-9037 831-3105/037-000 831-3105/037-9037 831-3105/1019-004 831-3105/1019-050 831-3105/135-000 831-3106 831-3106/000-9037 831-3106/037-000 831-3106/037-9037 831-3106/135-000 831-3107 831-3107/000-9037 831-3107/037-000 831-3107/037-9037 831-3107/136-000 831-3108 831-3108/000-9037 831-3108/037-000 831-3108/037-9037 831-3108/136-000 831-3109 831-3109/037-000 831-3109/136-000 831-3202 831-3202/000-9034 831-3202/007-000 831-3202/007-9034 831-3202/133-000 831-3203 831-3203/000-9034 831-3203/007-000 831-3203/007-9034 831-3203/133-000 831-3204 831-3204/000-9034 831-3204/007-000 831-3204/007-9034 831-3204/135-000 831-3205 831-3205/000-9032 831-3205/000-9034 831-3205/007-000 831-3205/007-9034 831-3205/1020-004 831-3205/1020-050 831-3205/135-000 831-3206 831-3206/000-9034 831-3206/007-000 831-3206/007-9034 831-3206/135-000 831-3207 831-3207/000-9034 831-3207/007-000 831-3207/007-9034 831-3207/136-000 831-3208 831-3208/000-9034 831-3208/007-000 831-3208/007-9034 831-3208/136-000 831-3209 831-3209/007-000 831-3209/136-000 831-3602 831-3603 831-3604 831-3605 831-3606 831-3607 831-3608 831-3609 831-3622 831-3623 831-3624 831-3625 831-3626 831-3627 831-3628 831-3629 831-500
8313102/133000, 831 3102/133 000
