Datasheet Wago 831-3207/007-000 — Даташит
Серия831
Модель831-3207/007-000
1-проводная вилка; 100% защита от неправильного подсоединения; DIN-35 rail mounting; 10 мм²; Шаг контактов 7,62 мм; 7-пол.
1 238 ₽
Wago 831-3207/007-000 Wago 831-3207/007-000
Actuation typeOperating tool
Цветlight gray
Connection technology 2Quick-connect/Solder contact
Contact platingtin-plated
Country of originDE
Габариты: глубина46 mm / 1.811 inch
Fine-stranded conductor0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 6 mm²
Fire load0.929 MJ
GTIN4045454333812
Height39 mm / 1.535 inch
Height from upper-edge of DIN-35 rail34 mm / 1.339 inch
Material groupI
Mismating protectionYes
Number of Poles7
Number of connection types1
Number of levels1
Pin spacing7.62 mm (0.3 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solid conductor0.5 … 10 mm² / 20 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points7
Total number of potentials7
Type of mountingDIN-35 rail
Вес49.1 г
Ширина55.22 mm / 2.174 inch
8313207/007000, 831 3207/007 000
На английском языке: Datasheet Wago 831-3207/007-000
