Оптопары и оптореле Megawin
Datasheet Wago 831-3208/007-000 — Даташит
Серия831
Модель831-3208/007-000
1-проводная вилка; 100% защита от неправильного подсоединения; DIN-35 rail mounting; 10 мм²; Шаг контактов 7,62 мм; 8-пол.
Wago 831-3208/007-000 Wago 831-3208/007-000
Actuation typeOperating tool
Цветlight gray
Connection technology 2Quick-connect/Solder contact
Contact platingtin-plated
Country of originDE
Габариты: глубина46 mm / 1.811 inch
Fine-stranded conductor0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 6 mm²
Fire load1.041 MJ
GTIN4045454333829
Height39 mm / 1.535 inch
Height from upper-edge of DIN-35 rail34 mm / 1.339 inch
Material groupI
Mismating protectionYes
Number of Poles8
Number of connection types1
Number of levels1
Pin spacing7.62 mm (0.3 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solid conductor0.5 … 10 mm² / 20 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points8
Total number of potentials8
Type of mountingDIN-35 rail
Вес55.504 г
Ширина62.84 mm / 2.474 inch
8313208/007000, 831 3208/007 000
На английском языке: Datasheet Wago 831-3208/007-000
