Datasheet Wago 831-3603 — Даташит
Вилка THT; 1.0 x 1.2 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 7,62 мм; 3-пол.
|  Купить 831-3603 на РадиоЛоцман.Цены — от 607 до 710 ₽ 11 предложений от 4 поставщиков THT MALE HEADER 1.0 X 1.2 MM SOL | |||
| 831-3603 Wago | от 607 ₽ | ||
| 831-3603 | от 622 ₽ | ||
| 831-3603 Wago | 710 ₽ | ||
| 831-3603/108-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 14.8 mm / 0.583 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fire load | 0.146 MJ |
| GTIN | 4045454002114 |
| Height | 33 mm / 1.299 inch |
| Height from the surface | 29 mm / 1.142 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Number of levels | 1 |
| Number of solder pins per potential | 3 |
| PCB contact | THT |
| Pin spacing | 7.62 mm (0.3 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 41 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1.2 mm |
| Solder pin length | 4 мм |
| Total number of potentials | 3 |
| Вес | 8.81 г |
| Ширина | 25.74 mm / 1.013 inch |
Серия: 831 (100 из 103)
- 831-3102/037-000 831-3102/037-9037 831-3102/133-000 831-3103 831-3103/000-9037 831-3103/037-000 831-3103/037-9037 831-3103/133-000 831-3104 831-3104/000-9037 831-3104/037-000 831-3104/037-9037 831-3104/135-000 831-3105 831-3105/000-9035 831-3105/000-9037 831-3105/037-000 831-3105/037-9037 831-3105/1019-004 831-3105/1019-050 831-3105/135-000 831-3106 831-3106/000-9037 831-3106/037-000 831-3106/037-9037 831-3106/135-000 831-3107 831-3107/000-9037 831-3107/037-000 831-3107/037-9037 831-3107/136-000 831-3108 831-3108/000-9037 831-3108/037-000 831-3108/037-9037 831-3108/136-000 831-3109 831-3109/037-000 831-3109/136-000 831-3202 831-3202/000-9034 831-3202/007-000 831-3202/007-9034 831-3202/133-000 831-3203 831-3203/000-9034 831-3203/007-000 831-3203/007-9034 831-3203/133-000 831-3204 831-3204/000-9034 831-3204/007-000 831-3204/007-9034 831-3204/135-000 831-3205 831-3205/000-9032 831-3205/000-9034 831-3205/007-000 831-3205/007-9034 831-3205/1020-004 831-3205/1020-050 831-3205/135-000 831-3206 831-3206/000-9034 831-3206/007-000 831-3206/007-9034 831-3206/135-000 831-3207 831-3207/000-9034 831-3207/007-000 831-3207/007-9034 831-3207/136-000 831-3208 831-3208/000-9034 831-3208/007-000 831-3208/007-9034 831-3208/136-000 831-3209 831-3209/007-000 831-3209/136-000 831-3602 831-3603 831-3604 831-3605 831-3606 831-3607 831-3608 831-3609 831-3622 831-3623 831-3624 831-3625 831-3626 831-3627 831-3628 831-3629 831-500 831-503 831-505 831-506
8313603, 831 3603
