Datasheet Wago 831-3623 — Даташит
Вилка THT; 1.0 x 1.2 mm solder pin; угловые; 100% защита от неправильного подсоединения; Шаг контактов 7,62 мм; 3-пол.
THT MALE HEADER 1.0 X 1.2 MM SOL | |||
831-3623 Wago | 337 ₽ | ||
831-3623/108-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | PL |
Габариты: глубина | 29 mm / 1.142 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
Fire load | 0.144 MJ |
GTIN | 4045454002183 |
Height | 18.8 mm / 0.74 inch |
Height from the surface | 14.8 mm / 0.583 inch |
Material group | I |
Mismating protection | Yes |
Number of Poles | 3 |
Number of levels | 1 |
Number of solder pins per potential | 3 |
PCB contact | THT |
Pin spacing | 7.62 mm (0.3 inch) |
Rated current | 41 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1.2 mm |
Solder pin length | 4 мм |
Total number of potentials | 3 |
Вес | 8.205 г |
Ширина | 25.74 mm / 1.013 inch |
Серия: 831 (100 из 103)
- 831-3102/037-000 831-3102/037-9037 831-3102/133-000 831-3103 831-3103/000-9037 831-3103/037-000 831-3103/037-9037 831-3103/133-000 831-3104 831-3104/000-9037 831-3104/037-000 831-3104/037-9037 831-3104/135-000 831-3105 831-3105/000-9035 831-3105/000-9037 831-3105/037-000 831-3105/037-9037 831-3105/1019-004 831-3105/1019-050 831-3105/135-000 831-3106 831-3106/000-9037 831-3106/037-000 831-3106/037-9037 831-3106/135-000 831-3107 831-3107/000-9037 831-3107/037-000 831-3107/037-9037 831-3107/136-000 831-3108 831-3108/000-9037 831-3108/037-000 831-3108/037-9037 831-3108/136-000 831-3109 831-3109/037-000 831-3109/136-000 831-3202 831-3202/000-9034 831-3202/007-000 831-3202/007-9034 831-3202/133-000 831-3203 831-3203/000-9034 831-3203/007-000 831-3203/007-9034 831-3203/133-000 831-3204 831-3204/000-9034 831-3204/007-000 831-3204/007-9034 831-3204/135-000 831-3205 831-3205/000-9032 831-3205/000-9034 831-3205/007-000 831-3205/007-9034 831-3205/1020-004 831-3205/1020-050 831-3205/135-000 831-3206 831-3206/000-9034 831-3206/007-000 831-3206/007-9034 831-3206/135-000 831-3207 831-3207/000-9034 831-3207/007-000 831-3207/007-9034 831-3207/136-000 831-3208 831-3208/000-9034 831-3208/007-000 831-3208/007-9034 831-3208/136-000 831-3209 831-3209/007-000 831-3209/136-000 831-3602 831-3603 831-3604 831-3605 831-3606 831-3607 831-3608 831-3609 831-3622 831-3623 831-3624 831-3625 831-3626 831-3627 831-3628 831-3629 831-500 831-503 831-505 831-506
8313623, 831 3623
