Datasheet Wago 832-1106/037-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Посеребренные контакты; 16 мм²; Шаг контактов 10,16 мм; 6-пол.
![]() 12 предложений от 4 поставщиков Вставные Клеммные Колодки | |||
832-1106/037-000 Wago | 3 104 ₽ | ||
832-1106/037-000 | от 4 071 ₽ | ||
832-1106/037-000 Wago | от 4 515 ₽ | ||
832-1106/037-000 Wago | по запросу |
Actuation type | Push-button |
Цвет | light gray |
Contact plating | silver-plated |
Country of origin | DE |
Габариты: глубина | 49.8 mm / 1.961 inch |
Fine-stranded conductor | 0.75 … 25 mm² / 18 … 4 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.75 … 16 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.75 … 16 mm² |
GTIN | 4055143736817 |
Height | 29.1 mm / 1.146 inch |
Insulating material | Polybutylene terephthalate (PBT) |
Limit temperature range | -60 … +120 °C |
Locking of plug-in connection | locking lever |
Material group | I |
Material of the additional spring for socket contact | Chrome nickel spring steel (CrNi) |
Mismating protection | Yes |
Number of Poles | 6 |
Number of levels | 1 |
Packaging type | BOX |
Pin spacing | 10.16 mm (0.4 inch) |
Rated current | 76 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 1000 В |
Solid conductor | 0.75 … 16 mm² / 18 … 4 AWG |
Strip length | 18 … 20 mm / 0.71 … 0.79 Inch |
Total number of connection points | 6 |
Total number of potentials | 6 |
Вес | 81.916 г |
Ширина | 74.26 mm / 2.924 inch |
Серия: 832 (31)
- 832-1102 832-1102/037-000 832-1103 832-1103/037-000 832-1104 832-1104/037-000 832-1105 832-1105/037-000 832-1106 832-1106/037-000 832-1202 832-1203 832-1204 832-1205 832-1206 832-3602 832-3603 832-3604 832-3605 832-3606 832-3622 832-3623 832-3624 832-3625 832-3626 832-3642 832-3643 832-3644 832-3645 832-3646 832-500
8321106/037000, 832 1106/037 000
