Datasheet Wago 832-1204 — Даташит
1-проводная вилка; 100% защита от неправильного подсоединения; Нажимной рычаг; Посеребренные контакты; 16 мм²; Шаг контактов 10,16 мм
|  Купить 832-1204 на РадиоЛоцман.Цены — от 1 108 до 3 288 ₽ 14 предложений от 5 поставщиков Вставные Клеммные Колодки | |||
| 832-1204 | от 2 975 ₽ | ||
| 832-1204 Wago | от 3 199 ₽ | ||
| 832-1204 Wago | 3 288 ₽ | ||
| 832-1204 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact plating | silver-plated |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 50.6 mm / 1.992 inch |
| Fine-stranded conductor | 0.75 … 25 mm² / 18 … 4 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.75 … 16 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.75 … 16 mm² |
| GTIN | 4055143748988 |
| Height | 29.1 mm / 1.146 inch |
| Insulating material | Polybutylene terephthalate (PBT) |
| Limit temperature range | -60 … +120 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Packaging type | BOX |
| Pin spacing | 10.16 mm (0.4 inch) |
| Rated current | 76 A |
| Rated impulse voltage (II / 2) | 8 kV |
| Rated impulse voltage (III / 2) | 8 kV |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 1000 В |
| Rated voltage (III / 3) | 1000 В |
| Solid conductor | 0.75 … 16 mm² / 18 … 4 AWG |
| Strip length | 18 … 20 mm / 0.71 … 0.79 Inch |
| Total number of connection points | 4 |
| Total number of potentials | 4 |
| Вес | 49.438 г |
| Ширина | 41.94 mm / 1.651 inch |
Серия: 832 (31)
- 832-1102 832-1102/037-000 832-1103 832-1103/037-000 832-1104 832-1104/037-000 832-1105 832-1105/037-000 832-1106 832-1106/037-000 832-1202 832-1203 832-1204 832-1205 832-1206 832-3602 832-3603 832-3604 832-3605 832-3606 832-3622 832-3623 832-3624 832-3625 832-3626 832-3642 832-3643 832-3644 832-3645 832-3646 832-500
8321204, 832 1204
