Datasheet Wago 832-3644 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; прямые; 100% защита от неправильного подсоединения; Посеребренные контакты; Шаг контактов 10,16 мм; 4-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
832-3644 Wago | 762 ₽ | ||
832-3644 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Contact plating | silver-plated |
Country of origin | DE |
Габариты: глубина | 32 mm / 1.26 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
GTIN | 4055143735421 |
Height | 20.5 mm / 0.807 inch |
Height from the surface | 16.5 mm / 0.65 inch |
Insulating material | Polybutylene terephthalate (PBT) |
Limit temperature range | -60 … +120 °C |
Material group | I |
Mating direction to the PCB | 180 ° |
Mismating protection | Yes |
Number of Poles | 4 |
Number of levels | 1 |
Number of solder pins per potential | 3 |
PCB contact | THT |
Packaging type | BOX |
Pin spacing | 10.16 mm (0.4 inch) |
Rated current | 76 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 800 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 4 мм |
Total number of potentials | 4 |
Вес | 21.634 г |
Ширина | 41.94 mm / 1.651 inch |
Серия: 832 (31)
- 832-1102 832-1102/037-000 832-1103 832-1103/037-000 832-1104 832-1104/037-000 832-1105 832-1105/037-000 832-1106 832-1106/037-000 832-1202 832-1203 832-1204 832-1205 832-1206 832-3602 832-3603 832-3604 832-3605 832-3606 832-3622 832-3623 832-3624 832-3625 832-3626 832-3642 832-3643 832-3644 832-3645 832-3646 832-500
8323644, 832 3644
