Datasheet Wago 890-835 — Даташит
Штекер; - для печатных плат; 5-пол.; Кодирование А
| PLUG FOR PCBS STRAIGHT 5-POLE | |||
| 890-835 Wago | по запросу | ||
| 890-835/011-000 Wago | по запросу | ||
| 043-8908-35 | по запросу | ||
| Coding | A |
| Цвет | white |
| Connector connection type | for PCBs |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 12.2 mm / 0.48 inch |
| Design | straight |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1 ... - 0.1) мм |
| Fire load | 0.091 MJ |
| GTIN | 4050821695608 |
| Height | 31.9 mm / 1.256 inch |
| Height from the surface | 28.4 mm / 1.118 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 1 2 3 |
| Mating direction to the PCB | 90 ° |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | N ⏚ 1 2 3 |
| Product Group | 20 (WINSTA) |
| Rated current | 13 A |
| Rated voltage (III / 3) | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Solder pin arrangement | 2 in-line solder pins/pole |
| Solder pin dimensions | 1 x 0.8 mm |
| Solder pin length | 3.5 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of potentials | 5 |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 4.777 г |
| Ширина | 23.6 mm / 0.929 inch |
Серия: 890 (100 из 384)
- 890-773 890-773/071-000 890-773/073-000 890-774 890-774/071-000 890-774/072-000 890-774/073-000 890-775/073-000 890-782 890-782/080-000 890-782/082-000 890-783 890-783/081-000 890-783/082-000 890-784 890-784/081-000 890-785/080-000 890-785/082-000 890-792 890-792/080-000 890-792/082-000 890-793 890-793/081-000 890-793/082-000 890-794 890-794/081-000 890-795/080-000 890-795/082-000 890-802 890-802/011-000 890-812 890-813/011-000 890-814 890-814/011-000 890-815 890-815/011-000 890-822 890-822/011-000 890-823 890-823/011-000 890-824 890-824/011-000 890-825 890-825/011-000 890-832 890-832/011-000 890-833 890-833/011-000 890-834 890-834/011-000 890-835 890-835/011-000 890-842 890-842/011-000 890-843 890-843/011-000 890-844 890-844/011-000 890-845 890-845/011-000 890-852 890-852/011-000 890-853 890-853/011-000 890-854 890-854/011-000 890-855 890-855/011-000 890-862 890-862/011-000 890-863 890-863/011-000 890-864 890-864/011-000 890-865 890-865/011-000 890-872 890-872/011-000 890-873 890-873/011-000 890-874 890-874/011-000 890-875 890-875/011-000 890-882 890-882/011-000 890-883 890-883/011-000 890-884 890-884/011-000 890-885 890-885/011-000 890-892 890-892/011-000 890-893 890-893/011-000 890-894 890-894/011-000 890-929 890-930
