Datasheet Wago 890-862/011-000 — Даташит
Гнездо для печатных плат; угловое; 2-полюсное; Код B
SOCKET FOR PCBS ANGLED 2-POLE | |||
890-862/011-000 Wago | по запросу | ||
Coding | B |
Цвет | light green |
Connector connection type | for PCBs |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 28.4 mm / 1.118 inch |
Design | angled |
Drilled hole diameter (tolerance) | 1.3(+ 0.1 ... - 0.1) мм |
Fire load | 0.046 MJ |
GTIN | 4050821695998 |
Height | 15.7 mm / 0.618 inch |
Height from the surface | 12.2 mm / 0.48 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | 1 2 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | 1 2 |
Rated current | 16 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solder pin arrangement | 2 in-line solder pins/pole |
Solder pin dimensions | 1 x 0.8 mm |
Solder pin length | 3.5 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of potentials | 2 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 2.47 г |
Ширина | 10.4 mm / 0.41 inch |
Серия: 890 (100 из 384)
- 890-782 890-782/080-000 890-782/082-000 890-783 890-783/081-000 890-783/082-000 890-784 890-784/081-000 890-785/080-000 890-785/082-000 890-792 890-792/080-000 890-792/082-000 890-793 890-793/081-000 890-793/082-000 890-794 890-794/081-000 890-795/080-000 890-795/082-000 890-802 890-802/011-000 890-812 890-813/011-000 890-814 890-814/011-000 890-815 890-815/011-000 890-822 890-822/011-000 890-823 890-823/011-000 890-824 890-824/011-000 890-825 890-825/011-000 890-832 890-832/011-000 890-833 890-833/011-000 890-834 890-834/011-000 890-835 890-835/011-000 890-842 890-842/011-000 890-843 890-843/011-000 890-844 890-844/011-000 890-845 890-845/011-000 890-852 890-852/011-000 890-853 890-853/011-000 890-854 890-854/011-000 890-855 890-855/011-000 890-862 890-862/011-000 890-863 890-863/011-000 890-864 890-864/011-000 890-865 890-865/011-000 890-872 890-872/011-000 890-873 890-873/011-000 890-874 890-874/011-000 890-875 890-875/011-000 890-882 890-882/011-000 890-883 890-883/011-000 890-884 890-884/011-000 890-885 890-885/011-000 890-892 890-892/011-000 890-893 890-893/011-000 890-894 890-894/011-000 890-929 890-930 890-944 890-945 890-979 890-980 890-982 890-983 890-994 890-995
890862/011000, 890 862/011 000
