Datasheet Wago 2060 — Даташит
Производитель | Wago |
Серия | 2060 |
![]() 30 предложений от 7 поставщиков Клеммная колодка типа провод к плате, White, 1 вывод(-ов), 24 AWG, 18 AWG, 0.75 мм², Вставной | |||
2060-1451/998-404 Wago | 28 ₽ | ||
2060-1451/998-404 Wago | 73 ₽ | ||
2060-1451/998-404 Wago | от 107 ₽ | ||
2060-1451/998-404 Wago | от 128 ₽ |
Parameters / Models | 2060-1451/998-404![]() | 2060-1452/998-404![]() | 2060-1453/998-404![]() | 2060-1471/998-404![]() | 2060-1472/998-404![]() | 2060-1473/998-404![]() | 2060-1852/998-404![]() | 2060-1872/998-404![]() | 2060-451/998-404![]() | 2060-452/998-404![]() | 2060-453/998-404![]() | 2060-471/998-404![]() | 2060-472/998-404![]() | 2060-473/998-404![]() | 2060-852/998-404![]() | 2060-872/998-404![]() | 2060-951/028-000![]() | 2060-952/028-000![]() | 2060-952/030-000![]() | 2060-953/028-000![]() | 2060-954/028-000![]() | 2060-962/028-000![]() |
Actuation type | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | ||||||
Цвет | white | white | white | black | black | black | white | black | white | white | white | black | black | black | white | black | white | white | white | white | white | white |
Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | ||||||
Contact material | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy |
Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | silver-plated | silver-plated | silver-plated | silver-plated | silver-plated | silver-plated |
Country of origin | CN | CH | CH | CN | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CN | CN | CN | CN | CN | CN |
Габариты: глубина | 12.7 mm / 0.5 inch | 12.7 mm / 0.5 inch | 12.7 mm / 0.5 inch | 12.7 mm / 0.5 inch | 12.7 mm / 0.5 inch | 12.7 mm / 0.5 inch | 12.7 mm / 0.5 inch | 12.7 mm / 0.5 inch | 13.1 mm / 0.516 inch | 13.1 mm / 0.516 inch | 13.1 mm / 0.516 inch | 13.1 mm / 0.516 inch | 13.1 mm / 0.516 inch | 13.1 mm / 0.516 inch | 13.1 mm / 0.516 inch | 13.1 mm / 0.516 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 30 mm / 1.181 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch |
Fine-stranded conductor | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | ||||||
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | ||||||
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | 0.25 … 0.34 mm² | ||||||
Fire load, MJ | 0.003 | 0.004 | 0.001 | 0.003 | 0.003 | 0.004 | 0.008 | 0.003 | ||||||||||||||
Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 |
GTIN | 4055143331227 | 4055143331203 | 4055143331180 | 4055143331234 | 4055143331210 | 4055143331197 | 4055143331173 | 4055143342643 | 4055143541237 | 4055143135078 | 4055143135085 | 4055143251198 | 4055143251181 | 4055143251174 | 4055143135092 | 4055143251167 | 4055143303880 | 4055143303859 | 4055143339827 | 4055143303873 | 4055143303842 | 4055143322898 |
Height | 6.9 mm / 0.272 inch | 6.9 mm / 0.272 inch | 6.9 mm / 0.272 inch | 6.9 mm / 0.272 inch | 6.9 mm / 0.272 inch | 6.9 mm / 0.272 inch | 6.9 mm / 0.272 inch | 6.9 mm / 0.272 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 2.6 mm / 0.102 inch | 2.6 mm / 0.102 inch | 2.6 mm / 0.102 inch | 2.6 mm / 0.102 inch | 2.6 mm / 0.102 inch | 2.6 mm / 0.102 inch |
Height from the surface | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | 4.5 mm / 0.177 inch | ||||||||||||||
Insulating material | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyphtalamide (PPA GF) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 |
Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C |
Material group | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I |
Number of Poles | 1 | 2 | 3 | 1 | 2 | 3 | 2 | 2 | 1 | 2 | 3 | 1 | 2 | 3 | 2 | 2 | 1 | 2 | 2 | 3 | 4 | 2 |
Number of connection types | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||
Number of solder pins per potential | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | ||||||||||||||
PCB contact | THR | THR | THR | THR | THR | THR | THR | THR | SMD | SMD | SMD | SMD | SMD | SMD | SMD | SMD | ||||||
Packaging type | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | ||||
Pin spacing | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 8 mm (0.314 inch) | 8 mm (0.314 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 8 mm (0.314 inch) | 8 mm (0.314 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 4 mm (0.157 inch) | 8 mm (0.314 inch) |
Plated through-hole diameter (THR), мм | 1.5 (+ 0.1) | 1.5 (+ 0.1) | 1.5 (+ 0.1) | 1.5 (+ 0.1) | 1.5 (+ 0.1) | 1.5 (+ 0.1) | 1.5 (+ 0.1) | 1.5 (+ 0.1) | ||||||||||||||
Product Group | 33 (Printed Circuit) | 33 (Printed Circuit) | 33 (Printed Circuit) | 33 (Printed Circuit) | ||||||||||||||||||
Rated current, A | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 |
Rated impulse voltage (II / 2), kV | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 | 6 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 | 6 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 |
Rated impulse voltage (III / 2), kV | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 | 6 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 | 6 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 |
Rated impulse voltage (III / 3), kV | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 | 6 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 | 6 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 6 |
Rated voltage (II / 2), В | 320 | 320 | 320 | 320 | 320 | 320 | 1000 | 1000 | 320 | 320 | 320 | 320 | 320 | 320 | 1000 | 1000 | 320 | 320 | 320 | 320 | 320 | 1000 |
Rated voltage (III / 2), В | 160 | 160 | 160 | 160 | 160 | 160 | 630 | 630 | 160 | 160 | 160 | 160 | 160 | 160 | 630 | 630 | 160 | 160 | 160 | 160 | 160 | 630 |
Rated voltage (III / 3), В | 63 | 63 | 63 | 63 | 63 | 63 | 400 | 400 | 63 | 63 | 63 | 63 | 63 | 63 | 400 | 400 | 63 | 63 | 63 | 63 | 63 | 400 |
Reel diameter of tape-and-reel packaging, мм | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | 330 | ||||||
Solder pin arrangement | within the terminal block, in line | over the entire terminal strip, in line | over the entire terminal strip, in line | within the terminal block, in line | over the entire terminal strip, in line | over the entire terminal strip, in line | over the entire terminal strip, in line | over the entire terminal strip, in line | ||||||||||||||
Solder pin dimensions | 1.2 x 0.75 mm | 1.2 x 0.75 mm | 1.2 x 0.75 mm | 1.2 x 0.75 mm | 1.2 x 0.75 mm | 1.2 x 0.75 mm | 1.2 x 0.75 mm | 1.2 x 0.75 mm | ||||||||||||||
Solder pin length, мм | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | ||||||||||||||
Solid conductor | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | 0.2 … 0.75 mm² / 24 … 18 AWG | ||||||
Strip length | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | 7 … 9 mm / 0.28 … 0.35 Inch | ||||||
Tape width, мм | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | ||||||
Total number of connection points | 1 | 2 | 3 | 1 | 2 | 3 | 2 | 2 | 1 | 2 | 3 | 1 | 2 | 3 | 2 | 2 | ||||||
Total number of potentials | 1 | 2 | 3 | 1 | 2 | 3 | 2 | 2 | 1 | 2 | 3 | 1 | 2 | 3 | 2 | 2 | 1 | 2 | 2 | 3 | 4 | 2 |
Вес, г | 0.25 | 0.518 | 0.769 | 0.25 | 0.518 | 0.769 | 0.618 | 0.618 | 0.25 | 0.518 | 1.111 | 0.25 | 0.518 | 0.769 | 0.618 | 0.618 | 0.23 | 0.46 | 0.49 | 0.69 | 0.93 | 0.49 |
Ширина | 3.9 mm / 0.154 inch | 7.9 mm / 0.311 inch | 11.9 mm / 0.467 inch | 3.9 mm / 0.154 inch | 7.9 mm / 0.311 inch | 11.9 mm / 0.467 inch | 11.9 mm / 0.467 inch | 11.9 mm / 0.467 inch | 3.9 mm / 0.154 inch | 7.9 mm / 0.311 inch | 11.9 mm / 0.469 inch | 3.9 mm / 0.154 inch | 7.9 mm / 0.311 inch | 11.9 mm / 0.469 inch | 11.9 mm / 0.469 inch | 11.9 mm / 0.469 inch | 3.4 mm / 0.134 inch | 7.4 mm / 0.291 inch | 7.4 mm / 0.291 inch | 11.4 mm / 0.449 inch | 15.4 mm / 0.606 inch | 11.4 mm / 0.449 inch |
Серия: 2060 (22)
- 2060-1451/998-404 2060-1452/998-404 2060-1453/998-404 2060-1471/998-404 2060-1472/998-404 2060-1473/998-404 2060-1852/998-404 2060-1872/998-404 2060-451/998-404 2060-452/998-404 2060-453/998-404 2060-471/998-404 2060-472/998-404 2060-473/998-404 2060-852/998-404 2060-872/998-404 2060-951/028-000 2060-952/028-000 2060-952/030-000 2060-953/028-000 2060-954/028-000 2060-962/028-000
- PCB Interconnect
