Datasheet Wago 2060-1451/998-404 — Даташит
Клеммная колодка THR PCB; Кнопка; 0,75 мм²; Шаг контактов 4 мм; 1-полюсный; Зажим Push-in CAGE CLAMP; в упаковке в виде ленты и катушки
|  Купить 2060-1451/998-404 на РадиоЛоцман.Цены — от 27 до 128 ₽ 30 предложений от 7 поставщиков Клеммная колодка типа провод к плате, White, 1 вывод(-ов), 24 AWG, 18 AWG, 0.75 мм², Вставной | |||
| 2060-1451/998-404 Wago | 73 ₽ | ||
| 2060-1451/998-404 | от 89 ₽ | ||
| 2060-1451/998-404 Wago | от 103 ₽ | ||
| 2060-1451/998-404 Wago | по запросу | ||
| Actuation type | Push-button |
| Цвет | white |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Copper alloy |
| Country of origin | CN |
| Габариты: глубина | 12.7 mm / 0.5 inch |
| Fine-stranded conductor | 0.2 … 0.75 mm² / 24 … 18 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.34 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.34 mm² |
| Fire load | 0.003 MJ |
| GTIN | 4055143331227 |
| Height | 6.9 mm / 0.272 inch |
| Height from the surface | 4.5 mm / 0.177 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THR |
| Packaging type | BOX |
| Pin spacing | 4 mm (0.157 inch) |
| Plated through-hole diameter (THR) | 1.5 (+ 0.1) мм |
| Rated current | 9 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 63 В |
| Reel diameter of tape-and-reel packaging | 330 мм |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 1.2 x 0.75 mm |
| Solder pin length | 2.4 мм |
| Solid conductor | 0.2 … 0.75 mm² / 24 … 18 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Tape width | 24 мм |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Вес | 0.25 г |
| Ширина | 3.9 mm / 0.154 inch |
Серия: 2060 (22)
- 2060-1451/998-404 2060-1452/998-404 2060-1453/998-404 2060-1471/998-404 2060-1472/998-404 2060-1473/998-404 2060-1852/998-404 2060-1872/998-404 2060-451/998-404 2060-452/998-404 2060-453/998-404 2060-471/998-404 2060-472/998-404 2060-473/998-404 2060-852/998-404 2060-872/998-404 2060-951/028-000 2060-952/028-000 2060-952/030-000 2060-953/028-000 2060-954/028-000 2060-962/028-000
- PCB Interconnect
20601451/998404, 2060 1451/998 404
