Datasheet Wago 2061 — Даташит
Серия2061
Datasheet Wago 2061
Parameters / Models2061-1601/998-404
2061-1601/998-404
2061-1602/998-404
2061-1602/998-404
2061-1603/998-404
2061-1603/998-404
2061-1621/998-404
2061-1621/998-404
2061-1622/998-404
2061-1622/998-404
2061-1623/998-404
2061-1623/998-404
2061-1641/998-404
2061-1641/998-404
2061-1642/998-404
2061-1642/998-404
2061-1643/998-404
2061-1643/998-404
2061-1661/998-404
2061-1661/998-404
2061-1662/998-404
2061-1662/998-404
2061-1663/998-404
2061-1663/998-404
2061-601/998-404
2061-601/998-404
2061-602/998-404
2061-602/998-404
2061-603/998-404
2061-603/998-404
2061-621/998-404
2061-621/998-404
2061-622/998-404
2061-622/998-404
2061-623/998-404
2061-623/998-404
Actuation typePush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-button
Цветwhitewhitewhiteblackblackblackwhitewhitewhiteblackblackblackwhitewhitewhiteblackblackblack
Connection technologyPush-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Contact materialCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloyCopper alloy
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originCHCNCNCNCHCHCHCHCHCHCHCHCNCHCHCNCHCN
Габариты: глубина15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.2 mm / 0.598 inch15.8 mm / 0.622 inch15.8 mm / 0.622 inch15.8 mm / 0.622 inch15.8 mm / 0.622 inch15.8 mm / 0.622 inch15.8 mm / 0.622 inch
Fine-stranded conductor0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²0.5 … 0.75 mm²
Fire load, MJ0.0170.0260.0080.0080.0080.026
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0
GTIN405514327471540551432746924055143274753405514327473940551432747084055143274760405514327472240551432746784055143274777405514327474640551432746854055143274784405514327806540508218598024055143242783405514325112940551432407584055143251105
Height8 mm / 0.315 inch8 mm / 0.315 inch8 mm / 0.315 inch8 mm / 0.315 inch8 mm / 0.315 inch8 mm / 0.315 inch7.1 mm / 0.28 inch7.1 mm / 0.28 inch7.1 mm / 0.28 inch7.1 mm / 0.28 inch7.1 mm / 0.28 inch7.1 mm / 0.28 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch
Height from the surface5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch5.6 mm / 0.22 inch
Insulating materialPolyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)Polyphtalamide (PPA GF)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C
Material groupIIIIIIIIIIIIIIIIII
Number of Poles123123123123123123
Number of connection types111111111111111111
Number of levels111111111111111111
Number of solder pins per potential222222222222
PCB contactTHRTHRTHRTHRTHRTHRTHRTHRTHRTHRTHRTHRSMDSMDSMDSMDSMDSMD
Packaging typeBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOX
Pin spacing6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)6 mm (0.24 inch)
Plated through-hole diameter (THR), мм1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)1.5 (+ 0.1)
Rated current, A17.517.517.517.517.517.517.517.517.517.517.517.517.517.517.517.517.517.5
Rated impulse voltage (II / 2), kV444444444444444444
Rated impulse voltage (III / 2), kV444444444444444444
Rated impulse voltage (III / 3), kV444444444444444444
Rated voltage (II / 2), В630630630630630630630630630630630630630630630630630630
Rated voltage (III / 2), В320320320320320320320320320320320320320320320320320320
Rated voltage (III / 3), В250250250250250250250250250250250250250250250250250250
Reel diameter of tape-and-reel packaging, мм330330330330330330330330330330330330330330330330330330
Solder pin arrangementwithin the terminal block, in lineover the entire terminal strip, in lineover the entire terminal strip, in linewithin the terminal block, in lineover the entire terminal strip, in lineover the entire terminal strip, in linewithin the terminal block, in lineover the entire terminal strip, in lineover the entire terminal strip, in linewithin the terminal block, in lineover the entire terminal strip, in lineover the entire terminal strip, in line
Solder pin dimensions1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm1.2 x 0.35 mm
Solder pin length, мм2.42.42.42.42.42.41.51.51.51.51.51.5
Solid conductor0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG
Strip length7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch7 … 10 mm / 0.28 … 0.39 Inch
Tape width, мм242424242424242424242424242424242424
Total number of connection points123123123123123123
Total number of potentials123123123123123123
Вес, г0.5341.0671.630.541.0671.630.5241.0471.60.5241.0471.60.4181.0531.6090.5271.0531.61
Ширина5.7 mm / 0.224 inch11.7 mm / 0.461 inch17.7 mm / 0.697 inch5.7 mm / 0.224 inch11.7 mm / 0.461 inch17.7 mm / 0.697 inch5.7 mm / 0.224 inch11.7 mm / 0.461 inch17.7 mm / 0.697 inch5.7 mm / 0.224 inch11.7 mm / 0.461 inch17.7 mm / 0.697 inch5.7 mm / 0.224 inch11.7 mm / 0.461 inch17.7 mm / 0.697 inch5.7 mm / 0.224 inch11.7 mm / 0.461 inch17.7 mm / 0.697 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 2061
Политика конфиденциальности
