Datasheet Wago 2061-1603/998-404 — Даташит
Клеммная колодка THR PCB; Кнопка; 1,5 мм²; Шаг контактов 6 мм; 3-полюсный; Зажим Push-in CAGE CLAMP; в упаковке в виде ленты и катушки
![]() Клеммные Колодки типа Провод-плата | |||
2061-1603/998-404 Wago | 322 ₽ | ||
2061-1603/998-404 Wago | 535 ₽ | ||
2061-1603/998-404 Wago | по запросу |
Actuation type | Push-button |
Цвет | white |
Contact material | Copper alloy |
Country of origin | CN |
Габариты: глубина | 15.2 mm / 0.598 inch |
Fine-stranded conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.5 … 0.75 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.5 … 0.75 mm² |
Fire load | 0.026 MJ |
GTIN | 4055143274753 |
Height | 8 mm / 0.315 inch |
Height from the surface | 5.6 mm / 0.22 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Number of Poles | 3 |
Number of levels | 1 |
PCB contact | THR |
Packaging type | BOX |
Pin spacing | 6 mm (0.24 inch) |
Plated through-hole diameter (THR) | 1.5 (+ 0.1) мм |
Rated current | 17.5 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Reel diameter of tape-and-reel packaging | 330 мм |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 1.2 x 0.35 mm |
Solder pin length | 2.4 мм |
Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 7 … 10 mm / 0.28 … 0.39 Inch |
Tape width | 24 мм |
Total number of connection points | 3 |
Total number of potentials | 3 |
Вес | 1.63 г |
Ширина | 17.7 mm / 0.697 inch |
Серия: 2061 (18)
- 2061-1601/998-404 2061-1602/998-404 2061-1603/998-404 2061-1621/998-404 2061-1622/998-404 2061-1623/998-404 2061-1641/998-404 2061-1642/998-404 2061-1643/998-404 2061-1661/998-404 2061-1662/998-404 2061-1663/998-404 2061-601/998-404 2061-602/998-404 2061-603/998-404 2061-621/998-404 2061-622/998-404 2061-623/998-404
- PCB Interconnect
20611603/998404, 2061 1603/998 404
