Datasheet Wago 2061-1661/998-404 — Даташит
Клеммная колодка THR PCB; Кнопка; 1,5 мм²; Шаг контактов 6 мм; 1-полюсный; Зажим Push-in CAGE CLAMP; в упаковке в виде ленты и катушки
Купить 2061-1661/998-404 на РадиоЛоцман.Цены — от 116 до 181 ₽10 предложений от 4 поставщиков Клеммная колодка типа провод к плате, Black, 1 вывод(-ов), 20 AWG, 16 AWG, 1.5 мм², Вставной | |||
| 2061-1661/998-404 Wago | от 116 ₽ | ||
| 2061-1661/998-404 | от 119 ₽ | ||
| 2061-1661/998-404 Wago | 132 ₽ | ||
| 2061-1661/998-404 Wago | от 181 ₽ | ||
| Actuation type | Push-button |
| Цвет | black |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Copper alloy |
| Country of origin | CH |
| Габариты: глубина | 15.2 mm / 0.598 inch |
| Fine-stranded conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 0.75 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 0.75 mm² |
| GTIN | 4055143274746 |
| Height | 7.1 mm / 0.28 inch |
| Height from the surface | 5.6 mm / 0.22 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THR |
| Packaging type | BOX |
| Pin spacing | 6 mm (0.24 inch) |
| Plated through-hole diameter (THR) | 1.5 (+ 0.1) мм |
| Rated current | 17.5 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Reel diameter of tape-and-reel packaging | 330 мм |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 1.2 x 0.35 mm |
| Solder pin length | 1.5 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 7 … 10 mm / 0.28 … 0.39 Inch |
| Tape width | 24 мм |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Вес | 0.524 г |
| Ширина | 5.7 mm / 0.224 inch |
Серия: 2061 (18)
- 2061-1601/998-404 2061-1602/998-404 2061-1603/998-404 2061-1621/998-404 2061-1622/998-404 2061-1623/998-404 2061-1641/998-404 2061-1642/998-404 2061-1643/998-404 2061-1661/998-404 2061-1662/998-404 2061-1663/998-404 2061-601/998-404 2061-602/998-404 2061-603/998-404 2061-621/998-404 2061-622/998-404 2061-623/998-404
- PCB Interconnect
20611661/998404, 2061 1661/998 404
