Datasheet Wago 2091-1112/000-1000 — Даташит
1-проводниковая розетка; Зажимная планка; прямая маркировка; 1,5; Шаг контактов 3,5 мм; 12-пол.
1-CONDUCTOR FEMALE PLUG; GRIPPIN | |||
| 2091-1112/000-1000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 11.4 mm / 0.449 inch |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.152 MJ |
| GTIN | 4050821365907 |
| Height | 38 mm / 1.496 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 12 |
| Вес | 6.15 г |
| Ширина | 42 mm / 1.654 inch |
Серия: 2091 (100 из 308)
- 2091-1102 2091-1102/000-1000 2091-1102/000-5000 2091-1102/002-000 2091-1102/002-1000 2091-1103 2091-1103/000-1000 2091-1103/000-5000 2091-1103/002-000 2091-1103/002-1000 2091-1104 2091-1104/000-1000 2091-1104/000-5000 2091-1104/002-000 2091-1104/002-1000 2091-1105 2091-1105/000-1000 2091-1105/000-5000 2091-1105/002-000 2091-1105/002-1000 2091-1106 2091-1106/000-1000 2091-1106/000-5000 2091-1106/002-000 2091-1106/002-1000 2091-1107 2091-1107/002-000 2091-1108 2091-1108/000-1000 2091-1108/000-5000 2091-1108/002-000 2091-1108/002-1000 2091-1110 2091-1110/000-1000 2091-1110/000-5000 2091-1110/002-000 2091-1110/002-1000 2091-1112 2091-1112/000-1000 2091-1112/000-5000 2091-1112/002-000 2091-1112/002-1000 2091-1122 2091-1123 2091-1124 2091-1125 2091-1126 2091-1128 2091-1130 2091-1132 2091-1152 2091-1152/000-5000 2091-1153 2091-1153/000-1000 2091-1153/000-5000 2091-1154 2091-1154/000-1000 2091-1154/000-5000 2091-1155 2091-1155/000-1000 2091-1155/000-5000 2091-1156 2091-1156/000-1000 2091-1156/000-5000 2091-1157 2091-1158 2091-1158/000-1000 2091-1158/000-5000 2091-1160 2091-1160/000-1000 2091-1160/000-5000 2091-1162 2091-1162/000-1000 2091-1162/000-5000 2091-1172 2091-1172/000-1000 2091-1172/000-5000 2091-1172/200-000 2091-1172/200-000/997-404 2091-1173 2091-1173/000-1000 2091-1173/000-5000 2091-1173/200-000 2091-1173/200-000/997-405 2091-1174 2091-1174/000-1000 2091-1174/000-5000 2091-1174/200-000 2091-1174/200-000/997-405 2091-1175 2091-1175/000-1000 2091-1175/000-5000 2091-1175/200-000 2091-1175/200-000/997-405 2091-1176 2091-1176/000-1000 2091-1176/000-5000 2091-1176/200-000 2091-1176/200-000/997-407 2091-1177/200-000/997-407
20911112/0001000, 2091 1112/000 1000
