Datasheet Wago 2091-1353/000-5000 — Даташит
1-conductor THT female header; Вывод под пайку 1 мм Ø; угловые; Зажимная планка; прямая маркировка; 1,5; Шаг контактов 3,5 мм; 3-пол.
1-CONDUCTOR THT FEMALE HEADER; 1 | |||
| 2091-1353/000-5000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 30 mm / 1.181 inch |
| Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.038 MJ |
| GTIN | 4050821365150 |
| Height | 11.4 mm / 0.449 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin diameter | 1 мм |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 1.842 г |
| Ширина | 10.5 mm / 0.413 inch |
Серия: 2091 (100 из 308)
- 2091-1174/000-5000 2091-1174/200-000 2091-1174/200-000/997-405 2091-1175 2091-1175/000-1000 2091-1175/000-5000 2091-1175/200-000 2091-1175/200-000/997-405 2091-1176 2091-1176/000-1000 2091-1176/000-5000 2091-1176/200-000 2091-1176/200-000/997-407 2091-1177/200-000/997-407 2091-1178 2091-1178/000-1000 2091-1178/000-5000 2091-1178/200-000 2091-1178/200-000/997-407 2091-1180 2091-1180/000-1000 2091-1180/000-5000 2091-1180/200-000 2091-1180/200-000/997-407 2091-1182 2091-1182/000-1000 2091-1182/000-5000 2091-1182/200-000 2091-1182/200-000/997-407 2091-1302 2091-1302/200-000 2091-1304 2091-1304/200-000 2091-1306 2091-1306/200-000 2091-1308 2091-1308/200-000 2091-1322 2091-1322/200-000 2091-1324 2091-1324/200-000 2091-1326 2091-1326/200-000 2091-1328 2091-1328/200-000 2091-1352 2091-1352/000-1000 2091-1352/000-5000 2091-1353 2091-1353/000-1000 2091-1353/000-5000 2091-1354 2091-1354/000-1000 2091-1354/000-5000 2091-1355 2091-1355/000-1000 2091-1355/000-5000 2091-1356 2091-1356/000-1000 2091-1356/000-5000 2091-1357 2091-1358 2091-1358/000-1000 2091-1358/000-5000 2091-1360 2091-1360/000-1000 2091-1360/000-5000 2091-1362 2091-1362/000-1000 2091-1362/000-5000 2091-1372 2091-1372/000-1000 2091-1372/000-5000 2091-1372/200-000 2091-1373 2091-1373/000-1000 2091-1373/000-5000 2091-1373/200-000 2091-1374 2091-1374/000-1000 2091-1374/000-5000 2091-1374/200-000 2091-1375 2091-1375/000-1000 2091-1375/000-5000 2091-1375/200-000 2091-1376 2091-1376/000-1000 2091-1376/000-5000 2091-1376/200-000 2091-1377 2091-1378 2091-1378/000-1000 2091-1378/000-5000 2091-1378/200-000 2091-1380 2091-1380/000-1000 2091-1380/000-5000 2091-1380/200-000 2091-1382
20911353/0005000, 2091 1353/000 5000
