Datasheet Wago 2091-1380/200-000 — Даташит
1-conductor THR female header; Вывод под пайку 1 мм Ø; угловые; 1,5; Шаг контактов 3,5 мм; 10-пол.
1-CONDUCTOR THR FEMALE HEADER; 1 | |||
| 2091-1380/200-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 14 mm / 0.551 inch |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.117 MJ |
| GTIN | 4050821396079 |
| Height | 11.4 mm / 0.449 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| PCB contact | THR |
| Pin spacing | 3.5 mm (0.138 inch) |
| Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin diameter | 1 мм |
| Solder pin length | 2.4 мм |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Вес | 5.788 г |
| Ширина | 35 mm / 1.378 inch |
Серия: 2091 (100 из 308)
- 2091-1353 2091-1353/000-1000 2091-1353/000-5000 2091-1354 2091-1354/000-1000 2091-1354/000-5000 2091-1355 2091-1355/000-1000 2091-1355/000-5000 2091-1356 2091-1356/000-1000 2091-1356/000-5000 2091-1357 2091-1358 2091-1358/000-1000 2091-1358/000-5000 2091-1360 2091-1360/000-1000 2091-1360/000-5000 2091-1362 2091-1362/000-1000 2091-1362/000-5000 2091-1372 2091-1372/000-1000 2091-1372/000-5000 2091-1372/200-000 2091-1373 2091-1373/000-1000 2091-1373/000-5000 2091-1373/200-000 2091-1374 2091-1374/000-1000 2091-1374/000-5000 2091-1374/200-000 2091-1375 2091-1375/000-1000 2091-1375/000-5000 2091-1375/200-000 2091-1376 2091-1376/000-1000 2091-1376/000-5000 2091-1376/200-000 2091-1377 2091-1378 2091-1378/000-1000 2091-1378/000-5000 2091-1378/200-000 2091-1380 2091-1380/000-1000 2091-1380/000-5000 2091-1380/200-000 2091-1382 2091-1382/000-1000 2091-1382/000-5000 2091-1382/200-000 2091-1402 2091-1402/005-000 2091-1402/200-000 2091-1402/205-000 2091-1403 2091-1403/005-000 2091-1403/200-000 2091-1403/205-000 2091-1404 2091-1404/005-000 2091-1404/200-000 2091-1404/205-000 2091-1405 2091-1405/005-000 2091-1405/200-000 2091-1405/205-000 2091-1406 2091-1406/005-000 2091-1406/200-000 2091-1406/205-000 2091-1407/200-000 2091-1408 2091-1408/005-000 2091-1408/200-000 2091-1408/205-000 2091-1410 2091-1410/005-000 2091-1410/200-000 2091-1410/205-000 2091-1412 2091-1412/200-000 2091-1412/205-000 2091-1422 2091-1422/005-000 2091-1422/200-000 2091-1422/200-000/997-405 2091-1422/205-000 2091-1423 2091-1423/005-000 2091-1423/200-000 2091-1423/200-000/997-406 2091-1423/205-000 2091-1424 2091-1424/005-000 2091-1424/200-000
20911380/200000, 2091 1380/200 000
