Datasheet Wago 2091-1428/200-000 — Даташит
Вилка под пайку THR; Вывод под пайку 1 мм Ø; угловые; Шаг контактов 3,5 мм; 8-пол.
THR MALE HEADER1.0 MM SOLDER PIN ANGLED, LIGHT GRAY | |||
| 2091-1428/200-000/997-406 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 17.5 mm / 0.689 inch |
| Fire load | 0.056 MJ |
| GTIN | 4050821396260 |
| Height | 14.8 mm / 0.583 inch |
| Height from the surface | 12.4 mm / 0.488 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Male locking latch |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 8 |
| Number of levels | 1 |
| PCB contact | THR |
| Pin spacing | 3.5 mm (0.138 inch) |
| Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin diameter | 1 мм |
| Solder pin length | 2.4 мм |
| Total number of potentials | 8 |
| Вес | 2.67 г |
| Ширина | 30 mm / 1.181 inch |
Серия: 2091 (100 из 308)
- 2091-1404/205-000 2091-1405 2091-1405/005-000 2091-1405/200-000 2091-1405/205-000 2091-1406 2091-1406/005-000 2091-1406/200-000 2091-1406/205-000 2091-1407/200-000 2091-1408 2091-1408/005-000 2091-1408/200-000 2091-1408/205-000 2091-1410 2091-1410/005-000 2091-1410/200-000 2091-1410/205-000 2091-1412 2091-1412/200-000 2091-1412/205-000 2091-1422 2091-1422/005-000 2091-1422/200-000 2091-1422/200-000/997-405 2091-1422/205-000 2091-1423 2091-1423/005-000 2091-1423/200-000 2091-1423/200-000/997-406 2091-1423/205-000 2091-1424 2091-1424/005-000 2091-1424/200-000 2091-1424/200-000/997-406 2091-1424/205-000 2091-1425 2091-1425/005-000 2091-1425/200-000 2091-1425/200-000/997-406 2091-1425/205-000 2091-1426 2091-1426/005-000 2091-1426/200-000 2091-1426/200-000/997-406 2091-1426/205-000 2091-1427/200-000 2091-1428 2091-1428/000-5000 2091-1428/005-000 2091-1428/200-000 2091-1428/200-000/997-406 2091-1428/205-000 2091-1430 2091-1430/005-000 2091-1430/200-000 2091-1430/205-000 2091-1432 2091-1432/200-000 2091-1432/205-000 2091-1502/002-000 2091-1503/002-000 2091-1503/002-3000 2091-1504/002-000 2091-1505/002-000 2091-1505/002-3000 2091-1506/002-000 2091-1508/002-000 2091-1510/002-000 2091-1510/002-3000 2091-1512/002-000 2091-1512/002-3000 2091-1522/002-000 2091-1522/020-000 2091-1523/002-000 2091-1523/002-3000 2091-1523/020-000 2091-1523/020-3000 2091-1524/002-000 2091-1524/020-000 2091-1525/002-000 2091-1525/002-3000 2091-1525/020-000 2091-1525/020-3000 2091-1526/002-000 2091-1526/020-000 2091-1528/002-000 2091-1528/020-000 2091-1530/002-000 2091-1530/002-3000 2091-1530/020-000 2091-1530/020-3000 2091-1532/002-000 2091-1532/002-3000 2091-1532/020-000 2091-1532/020-3000 2091-1600 2091-1600/002-000 2091-1601 2091-1601/002-000
20911428/200000, 2091 1428/200 000
