Datasheet Wago 2091-1512/002-000 — Даташит
Серия2091
Модель2091-1512/002-000
1-проводная вилка; Зажимная планка; 1,5; Шаг контактов 3,5 мм; 12-пол.
2091-1512/002-000
Actuation typePush-button
Цветlight gray
Contact platingtin-plated
Country of originDE
Габариты: глубина47 mm / 1.85 inch
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 14 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1.5 mm²
Fire load0.152 MJ
GTIN4055143541190
Height15.9 mm / 0.626 inch
Locking of plug-in connectionMale locking latch
Material groupI
Mismating protectionNo
Number of Poles12
Number of connection types1
Number of levels1
Rated current10 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)160 В
Solid conductor0.2 … 1.5 mm² / 24 … 14 AWG
Total number of connection points12
Total number of potentials12
Вес11.814 г
Ширина44 mm / 1.732 inch
Серия: 2091 (100 из 308)
20911512/002000, 2091 1512/002 000
На английском языке: Datasheet Wago 2091-1512/002-000
