Datasheet Wago 2091-1523/020-3000 — Даташит
1-проводная вилка; Монтажные ножки; Встроенный рычаг для размыкания; прямая маркировка; 1,5; Шаг контактов 3,5 мм; 3-пол.
1-CONDUCTOR MALE CONNECTOR; SNAP | |||
| 2091-1523/020-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Габариты: глубина | 28 mm / 1.102 inch |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Height | 20.4 mm / 0.803 inch |
| Height from the surface | 15.9 mm / 0.626 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Male locking latch |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Ширина | 10.5 mm / 0.413 inch |
Серия: 2091 (100 из 308)
- 2091-1406/205-000 2091-1407/200-000 2091-1408 2091-1408/005-000 2091-1408/200-000 2091-1408/205-000 2091-1410 2091-1410/005-000 2091-1410/200-000 2091-1410/205-000 2091-1412 2091-1412/200-000 2091-1412/205-000 2091-1422 2091-1422/005-000 2091-1422/200-000 2091-1422/200-000/997-405 2091-1422/205-000 2091-1423 2091-1423/005-000 2091-1423/200-000 2091-1423/200-000/997-406 2091-1423/205-000 2091-1424 2091-1424/005-000 2091-1424/200-000 2091-1424/200-000/997-406 2091-1424/205-000 2091-1425 2091-1425/005-000 2091-1425/200-000 2091-1425/200-000/997-406 2091-1425/205-000 2091-1426 2091-1426/005-000 2091-1426/200-000 2091-1426/200-000/997-406 2091-1426/205-000 2091-1427/200-000 2091-1428 2091-1428/000-5000 2091-1428/005-000 2091-1428/200-000 2091-1428/200-000/997-406 2091-1428/205-000 2091-1430 2091-1430/005-000 2091-1430/200-000 2091-1430/205-000 2091-1432 2091-1432/200-000 2091-1432/205-000 2091-1502/002-000 2091-1503/002-000 2091-1503/002-3000 2091-1504/002-000 2091-1505/002-000 2091-1505/002-3000 2091-1506/002-000 2091-1508/002-000 2091-1510/002-000 2091-1510/002-3000 2091-1512/002-000 2091-1512/002-3000 2091-1522/002-000 2091-1522/020-000 2091-1523/002-000 2091-1523/002-3000 2091-1523/020-000 2091-1523/020-3000 2091-1524/002-000 2091-1524/020-000 2091-1525/002-000 2091-1525/002-3000 2091-1525/020-000 2091-1525/020-3000 2091-1526/002-000 2091-1526/020-000 2091-1528/002-000 2091-1528/020-000 2091-1530/002-000 2091-1530/002-3000 2091-1530/020-000 2091-1530/020-3000 2091-1532/002-000 2091-1532/002-3000 2091-1532/020-000 2091-1532/020-3000 2091-1600 2091-1600/002-000 2091-1601 2091-1601/002-000 2091-1602 2091-1602/002-000 2091-1603 2091-1610 2091-1632/024-000 2091-1634/024-000 2091-1636/024-000 2091-1638/024-000
20911523/0203000, 2091 1523/020 3000
