Datasheet Wago 2092-1157 — Даташит
1-conductor THT female header; 1.4 mm Ø solder pin; прямые; Зажимная планка; 2,5 мм²; Шаг контактов 5 мм; 7-пол.
| 1-CONDUCTOR THT FEMALE HEADER; 1 | |||
| 2092-1157 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Conductor entry angle to the PCB | 90 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 13.4 mm / 0.528 inch |
| Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.164 MJ |
| GTIN | 4050821869382 |
| Height | 39 mm / 1.535 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 7 |
| Number of connection types | 1 |
| Number of levels | 1 |
| PCB contact | THT |
| Packaging type | BOX |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 26 (picoMAX) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin diameter | 1.4 мм |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Вес | 8.263 г |
| Ширина | 35 mm / 1.378 inch |
Серия: 2092 (100 из 338)
- 2092-1103/002-000 2092-1104 2092-1104/002-000 2092-1105 2092-1105/000-5000 2092-1105/002-000 2092-1106 2092-1106/000-5000 2092-1106/002-000 2092-1107 2092-1107/002-000 2092-1108 2092-1108/000-5000 2092-1108/002-000 2092-1109 2092-1109/002-000 2092-1110 2092-1110/000-5000 2092-1110/002-000 2092-1112 2092-1112/000-5000 2092-1112/002-000 2092-1122 2092-1122/000-5000 2092-1123 2092-1123/000-5000 2092-1124 2092-1124/000-5000 2092-1125 2092-1125/000-5000 2092-1126 2092-1126/000-5000 2092-1127 2092-1128 2092-1128/000-5000 2092-1129 2092-1130 2092-1130/000-5000 2092-1132 2092-1132/000-5000 2092-1152 2092-1152/000-5000 2092-1153 2092-1153/000-5000 2092-1154 2092-1154/000-5000 2092-1155 2092-1155/000-5000 2092-1156 2092-1156/000-5000 2092-1157 2092-1158 2092-1158/000-5000 2092-1159 2092-1160 2092-1160/000-5000 2092-1162 2092-1162/000-5000 2092-1172 2092-1172/000-5000 2092-1172/200-000 2092-1173 2092-1173/000-5000 2092-1173/200-000 2092-1174 2092-1174/000-5000 2092-1174/200-000 2092-1175 2092-1175/000-5000 2092-1175/200-000 2092-1176 2092-1176/000-5000 2092-1176/200-000 2092-1177 2092-1178 2092-1178/000-5000 2092-1178/200-000 2092-1179 2092-1180 2092-1180/000-5000 2092-1180/200-000 2092-1182 2092-1182/000-5000 2092-1182/200-000 2092-1302 2092-1302/200-000 2092-1303 2092-1303/200-000 2092-1304 2092-1304/200-000 2092-1305 2092-1305/200-000 2092-1306 2092-1306/200-000 2092-1322 2092-1322/200-000 2092-1323 2092-1323/200-000 2092-1324 2092-1324/200-000
20921157, 2092 1157
