Datasheet Wago 2092-1302 — Даташит
Розетка под пайку THT; 0.4 x 1.3 mm solder pin; прямые; Шаг контактов 5 мм; 2-пол.
THT FEMALE HEADER; 0.4 X 1.3 MM | |||
2092-1302 Wago | 87 ₽ | ||
2092-1302/200-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 13.6 mm / 0.535 inch |
Fire load | 0.046 MJ |
GTIN | 4050821163633 |
Height | 19.8 mm / 0.78 inch |
Height from the surface | 16.2 mm / 0.638 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THR |
Pin spacing | 5 mm (0.197 inch) |
Plated through-hole diameter (THR) | 1.5 (+ 0.1) мм |
Product Group | 26 (picoMAX) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin dimensions | 0.4 x 1.3 mm |
Solder pin length | 3.6 мм |
Total number of potentials | 2 |
Вес | 1.87 г |
Ширина | 10 mm / 0.394 inch |
Серия: 2092 (100 из 338)
- 2092-1128/000-5000 2092-1129 2092-1130 2092-1130/000-5000 2092-1132 2092-1132/000-5000 2092-1152 2092-1152/000-5000 2092-1153 2092-1153/000-5000 2092-1154 2092-1154/000-5000 2092-1155 2092-1155/000-5000 2092-1156 2092-1156/000-5000 2092-1157 2092-1158 2092-1158/000-5000 2092-1159 2092-1160 2092-1160/000-5000 2092-1162 2092-1162/000-5000 2092-1172 2092-1172/000-5000 2092-1172/200-000 2092-1173 2092-1173/000-5000 2092-1173/200-000 2092-1174 2092-1174/000-5000 2092-1174/200-000 2092-1175 2092-1175/000-5000 2092-1175/200-000 2092-1176 2092-1176/000-5000 2092-1176/200-000 2092-1177 2092-1178 2092-1178/000-5000 2092-1178/200-000 2092-1179 2092-1180 2092-1180/000-5000 2092-1180/200-000 2092-1182 2092-1182/000-5000 2092-1182/200-000 2092-1302 2092-1302/200-000 2092-1303 2092-1303/200-000 2092-1304 2092-1304/200-000 2092-1305 2092-1305/200-000 2092-1306 2092-1306/200-000 2092-1322 2092-1322/200-000 2092-1323 2092-1323/200-000 2092-1324 2092-1324/200-000 2092-1325 2092-1325/200-000 2092-1326 2092-1326/200-000 2092-1352 2092-1352/000-5000 2092-1353 2092-1353/000-5000 2092-1354 2092-1354/000-5000 2092-1355 2092-1355/000-5000 2092-1356 2092-1356/000-5000 2092-1357 2092-1358 2092-1358/000-5000 2092-1359 2092-1360 2092-1360/000-5000 2092-1362 2092-1362/000-5000 2092-1372 2092-1372/000-5000 2092-1373 2092-1373/000-5000 2092-1374 2092-1374/000-5000 2092-1375 2092-1375/000-5000 2092-1376 2092-1376/000-5000 2092-1377 2092-1378
20921302, 2092 1302
