Datasheet Wago 2092-1356 — Даташит
1-conductor THT female header; 1.4 mm Ø solder pin; угловые; Зажимная планка; 2,5 мм²; Шаг контактов 5 мм; 6-пол.
| 1-CONDUCTOR THT FEMALE HEADER1.4 MM SOLDER PIN ANGLED, LIGHT GRAY | |||
| 2092-1356 Wago | по запросу | ||
| 2092-1356/000-5000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 40.4 mm / 1.591 inch |
| Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.148 MJ |
| GTIN | 4050821165385 |
| Height | 13.4 mm / 0.528 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 6 |
| Number of connection types | 1 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 26 (picoMAX) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin diameter | 1.4 мм |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Вес | 7.069 г |
| Ширина | 30 mm / 1.181 inch |
Серия: 2092 (100 из 338)
- 2092-1173/000-5000 2092-1173/200-000 2092-1174 2092-1174/000-5000 2092-1174/200-000 2092-1175 2092-1175/000-5000 2092-1175/200-000 2092-1176 2092-1176/000-5000 2092-1176/200-000 2092-1177 2092-1178 2092-1178/000-5000 2092-1178/200-000 2092-1179 2092-1180 2092-1180/000-5000 2092-1180/200-000 2092-1182 2092-1182/000-5000 2092-1182/200-000 2092-1302 2092-1302/200-000 2092-1303 2092-1303/200-000 2092-1304 2092-1304/200-000 2092-1305 2092-1305/200-000 2092-1306 2092-1306/200-000 2092-1322 2092-1322/200-000 2092-1323 2092-1323/200-000 2092-1324 2092-1324/200-000 2092-1325 2092-1325/200-000 2092-1326 2092-1326/200-000 2092-1352 2092-1352/000-5000 2092-1353 2092-1353/000-5000 2092-1354 2092-1354/000-5000 2092-1355 2092-1355/000-5000 2092-1356 2092-1356/000-5000 2092-1357 2092-1358 2092-1358/000-5000 2092-1359 2092-1360 2092-1360/000-5000 2092-1362 2092-1362/000-5000 2092-1372 2092-1372/000-5000 2092-1373 2092-1373/000-5000 2092-1374 2092-1374/000-5000 2092-1375 2092-1375/000-5000 2092-1376 2092-1376/000-5000 2092-1377 2092-1378 2092-1378/000-5000 2092-1379 2092-1379/200-000 2092-1380 2092-1380/000-5000 2092-1382 2092-1382/000-5000 2092-1402 2092-1402/005-000 2092-1402/200-000 2092-1402/205-000 2092-1403 2092-1403/005-000 2092-1403/200-000 2092-1403/205-000 2092-1404 2092-1404/005-000 2092-1404/200-000 2092-1404/205-000 2092-1405 2092-1405/005-000 2092-1405/200-000 2092-1405/205-000 2092-1406 2092-1406/005-000 2092-1406/200-000 2092-1407 2092-1408
20921356, 2092 1356
