Datasheet Wago 2092-1373 — Даташит
1-conductor THT female header; 1.4 mm Ø solder pin; угловые; 2,5 мм²; Шаг контактов 5 мм; 3-пол.
1-CONDUCTOR THT FEMALE HEADER; 1 | |||
2092-1373 Wago | 176 ₽ | ||
2092-1373/000-5000 Wago | по запросу |
Actuation type | Push-button |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 15.4 mm / 0.606 inch |
Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Fire load | 0.067 MJ |
GTIN | 4050821164951 |
Height | 13.4 mm / 0.528 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mismating protection | No |
Number of Poles | 3 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Product Group | 26 (picoMAX) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin diameter | 1.4 мм |
Solder pin length | 3.6 мм |
Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 3 |
Total number of potentials | 3 |
Вес | 3.443 г |
Ширина | 15 mm / 0.591 inch |
Серия: 2092 (100 из 338)
- 2092-1178 2092-1178/000-5000 2092-1178/200-000 2092-1179 2092-1180 2092-1180/000-5000 2092-1180/200-000 2092-1182 2092-1182/000-5000 2092-1182/200-000 2092-1302 2092-1302/200-000 2092-1303 2092-1303/200-000 2092-1304 2092-1304/200-000 2092-1305 2092-1305/200-000 2092-1306 2092-1306/200-000 2092-1322 2092-1322/200-000 2092-1323 2092-1323/200-000 2092-1324 2092-1324/200-000 2092-1325 2092-1325/200-000 2092-1326 2092-1326/200-000 2092-1352 2092-1352/000-5000 2092-1353 2092-1353/000-5000 2092-1354 2092-1354/000-5000 2092-1355 2092-1355/000-5000 2092-1356 2092-1356/000-5000 2092-1357 2092-1358 2092-1358/000-5000 2092-1359 2092-1360 2092-1360/000-5000 2092-1362 2092-1362/000-5000 2092-1372 2092-1372/000-5000 2092-1373 2092-1373/000-5000 2092-1374 2092-1374/000-5000 2092-1375 2092-1375/000-5000 2092-1376 2092-1376/000-5000 2092-1377 2092-1378 2092-1378/000-5000 2092-1379 2092-1379/200-000 2092-1380 2092-1380/000-5000 2092-1382 2092-1382/000-5000 2092-1402 2092-1402/005-000 2092-1402/200-000 2092-1402/205-000 2092-1403 2092-1403/005-000 2092-1403/200-000 2092-1403/205-000 2092-1404 2092-1404/005-000 2092-1404/200-000 2092-1404/205-000 2092-1405 2092-1405/005-000 2092-1405/200-000 2092-1405/205-000 2092-1406 2092-1406/005-000 2092-1406/200-000 2092-1407 2092-1408 2092-1408/005-000 2092-1408/200-000 2092-1409 2092-1410 2092-1410/005-000 2092-1410/200-000 2092-1412 2092-1412/005-000 2092-1412/200-000 2092-1422 2092-1422/005-000 2092-1422/200-000
20921373, 2092 1373
