Datasheet Wago 2092-1403/200-000 — Даташит
Вилка под пайку THR; 1.4 mm Ø solder pin; прямые; Шаг контактов 5 мм; 3-пол.
| THR MALE HEADER; 1.4 MM SOLDER | |||
| 2092-1403/200-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 14.4 mm / 0.567 inch |
| Fire load | 0.045 MJ |
| GTIN | 4050821395645 |
| Height | 21.9 mm / 0.862 inch |
| Height from the surface | 19.5 mm / 0.768 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Male locking latch |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 3 |
| Number of levels | 1 |
| PCB contact | THR |
| Pin spacing | 5 mm (0.197 inch) |
| Plated through-hole diameter (THR) | 1.6 (+ 0.1) мм |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin diameter | 1.4 мм |
| Solder pin length | 2.4 мм |
| Total number of potentials | 3 |
| Вес | 2.06 г |
| Ширина | 17.2 mm / 0.677 inch |
Серия: 2092 (100 из 338)
- 2092-1323/200-000 2092-1324 2092-1324/200-000 2092-1325 2092-1325/200-000 2092-1326 2092-1326/200-000 2092-1352 2092-1352/000-5000 2092-1353 2092-1353/000-5000 2092-1354 2092-1354/000-5000 2092-1355 2092-1355/000-5000 2092-1356 2092-1356/000-5000 2092-1357 2092-1358 2092-1358/000-5000 2092-1359 2092-1360 2092-1360/000-5000 2092-1362 2092-1362/000-5000 2092-1372 2092-1372/000-5000 2092-1373 2092-1373/000-5000 2092-1374 2092-1374/000-5000 2092-1375 2092-1375/000-5000 2092-1376 2092-1376/000-5000 2092-1377 2092-1378 2092-1378/000-5000 2092-1379 2092-1379/200-000 2092-1380 2092-1380/000-5000 2092-1382 2092-1382/000-5000 2092-1402 2092-1402/005-000 2092-1402/200-000 2092-1402/205-000 2092-1403 2092-1403/005-000 2092-1403/200-000 2092-1403/205-000 2092-1404 2092-1404/005-000 2092-1404/200-000 2092-1404/205-000 2092-1405 2092-1405/005-000 2092-1405/200-000 2092-1405/205-000 2092-1406 2092-1406/005-000 2092-1406/200-000 2092-1407 2092-1408 2092-1408/005-000 2092-1408/200-000 2092-1409 2092-1410 2092-1410/005-000 2092-1410/200-000 2092-1412 2092-1412/005-000 2092-1412/200-000 2092-1422 2092-1422/005-000 2092-1422/200-000 2092-1422/205-000 2092-1423 2092-1423/005-000 2092-1423/200-000 2092-1423/205-000 2092-1424 2092-1424/005-000 2092-1424/200-000 2092-1424/205-000 2092-1425 2092-1425/005-000 2092-1425/200-000 2092-1425/205-000 2092-1426 2092-1426/005-000 2092-1426/200-000 2092-1427 2092-1428 2092-1428/005-000 2092-1428/200-000 2092-1429 2092-1430 2092-1430/005-000
20921403/200000, 2092 1403/200 000
