Datasheet Wago 2092-1423 — Даташит
Вилка THT; 1.4 mm Ø solder pin; угловые; Шаг контактов 5 мм; 3-пол.
THR MALE HEADER1.4 MM SOLDER PIN ANGLED, LIGHT GRAY | |||
2092-1423 Wago | 87 ₽ | ||
2092-1423/005-000 Wago | по запросу | ||
2092-1423/200-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 19.5 mm / 0.768 inch |
Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
Fire load | 0.045 MJ |
GTIN | 4050821163923 |
Height | 18 mm / 0.709 inch |
Height from the surface | 14.4 mm / 0.567 inch |
Insulating material | Polyphtalamide (PPA GF) |
Locking of plug-in connection | Male locking latch |
Material group | I |
Mismating protection | No |
Number of Poles | 3 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Product Group | 26 (picoMAX) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin diameter | 1.4 мм |
Solder pin length | 3.6 мм |
Total number of potentials | 3 |
Вес | 2.18 г |
Ширина | 17.2 mm / 0.677 inch |
Серия: 2092 (100 из 338)
- 2092-1373/000-5000 2092-1374 2092-1374/000-5000 2092-1375 2092-1375/000-5000 2092-1376 2092-1376/000-5000 2092-1377 2092-1378 2092-1378/000-5000 2092-1379 2092-1379/200-000 2092-1380 2092-1380/000-5000 2092-1382 2092-1382/000-5000 2092-1402 2092-1402/005-000 2092-1402/200-000 2092-1402/205-000 2092-1403 2092-1403/005-000 2092-1403/200-000 2092-1403/205-000 2092-1404 2092-1404/005-000 2092-1404/200-000 2092-1404/205-000 2092-1405 2092-1405/005-000 2092-1405/200-000 2092-1405/205-000 2092-1406 2092-1406/005-000 2092-1406/200-000 2092-1407 2092-1408 2092-1408/005-000 2092-1408/200-000 2092-1409 2092-1410 2092-1410/005-000 2092-1410/200-000 2092-1412 2092-1412/005-000 2092-1412/200-000 2092-1422 2092-1422/005-000 2092-1422/200-000 2092-1422/205-000 2092-1423 2092-1423/005-000 2092-1423/200-000 2092-1423/205-000 2092-1424 2092-1424/005-000 2092-1424/200-000 2092-1424/205-000 2092-1425 2092-1425/005-000 2092-1425/200-000 2092-1425/205-000 2092-1426 2092-1426/005-000 2092-1426/200-000 2092-1427 2092-1428 2092-1428/005-000 2092-1428/200-000 2092-1429 2092-1430 2092-1430/005-000 2092-1430/200-000 2092-1432 2092-1432/005-000 2092-1432/200-000 2092-1502/002-000 2092-1503/002-000 2092-1504/002-000 2092-1505/002-000 2092-1506/002-000 2092-1522/002-000 2092-1522/020-000 2092-1523/002-000 2092-1523/020-000 2092-1524/002-000 2092-1524/020-000 2092-1525/002-000 2092-1525/020-000 2092-1526/002-000 2092-1526/020-000 2092-1600 2092-1600/002-000 2092-1601 2092-1601/002-000 2092-1602 2092-1602/002-000 2092-1603 2092-1603/002-000 2092-1610
20921423, 2092 1423
