Datasheet Wago 2092-1430 — Даташит
Вилка THT; 1.4 mm Ø solder pin; угловые; Шаг контактов 5 мм; 10-пол.
THR MALE HEADER; 1.4 MM SOLDER | |||
2092-1430 Wago | 237 ₽ | ||
2092-1430/200-000 Wago | по запросу | ||
2092-1430/005-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 19.5 mm / 0.768 inch |
Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
Fire load | 0.107 MJ |
GTIN | 4050821163978 |
Height | 18 mm / 0.709 inch |
Height from the surface | 14.4 mm / 0.567 inch |
Insulating material | Polyphtalamide (PPA GF) |
Locking of plug-in connection | Male locking latch |
Material group | I |
Mismating protection | No |
Number of Poles | 10 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Product Group | 26 (picoMAX) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin diameter | 1.4 мм |
Solder pin length | 3.6 мм |
Total number of potentials | 10 |
Вес | 5.86 г |
Ширина | 52.2 mm / 2.055 inch |
Серия: 2092 (100 из 338)
- 2092-1403 2092-1403/005-000 2092-1403/200-000 2092-1403/205-000 2092-1404 2092-1404/005-000 2092-1404/200-000 2092-1404/205-000 2092-1405 2092-1405/005-000 2092-1405/200-000 2092-1405/205-000 2092-1406 2092-1406/005-000 2092-1406/200-000 2092-1407 2092-1408 2092-1408/005-000 2092-1408/200-000 2092-1409 2092-1410 2092-1410/005-000 2092-1410/200-000 2092-1412 2092-1412/005-000 2092-1412/200-000 2092-1422 2092-1422/005-000 2092-1422/200-000 2092-1422/205-000 2092-1423 2092-1423/005-000 2092-1423/200-000 2092-1423/205-000 2092-1424 2092-1424/005-000 2092-1424/200-000 2092-1424/205-000 2092-1425 2092-1425/005-000 2092-1425/200-000 2092-1425/205-000 2092-1426 2092-1426/005-000 2092-1426/200-000 2092-1427 2092-1428 2092-1428/005-000 2092-1428/200-000 2092-1429 2092-1430 2092-1430/005-000 2092-1430/200-000 2092-1432 2092-1432/005-000 2092-1432/200-000 2092-1502/002-000 2092-1503/002-000 2092-1504/002-000 2092-1505/002-000 2092-1506/002-000 2092-1522/002-000 2092-1522/020-000 2092-1523/002-000 2092-1523/020-000 2092-1524/002-000 2092-1524/020-000 2092-1525/002-000 2092-1525/020-000 2092-1526/002-000 2092-1526/020-000 2092-1600 2092-1600/002-000 2092-1601 2092-1601/002-000 2092-1602 2092-1602/002-000 2092-1603 2092-1603/002-000 2092-1610 2092-1630 2092-1632/024-000 2092-1633/024-000 2092-1634/024-000 2092-1635/024-000 2092-1636/024-000 2092-3102 2092-3102/002-000 2092-3102/002-1000 2092-3103 2092-3103/002-000 2092-3103/002-1000 2092-3104 2092-3104/002-000 2092-3105 2092-3105/002-000 2092-3105/002-1000 2092-3122 2092-3123 2092-3124
20921430, 2092 1430
