Datasheet Wago 2092-1432 — Даташит
Вилка THT; 1.4 mm Ø solder pin; угловые; Шаг контактов 5 мм; 12-пол.
| THT MALE HEADER; 1.4 MM SOLDER | |||
| 2092-1432 Wago | 269 ₽ | ||
| 2092-1432/005-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 19.5 mm / 0.768 inch |
| Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
| Fire load | 0.125 MJ |
| GTIN | 4050821163985 |
| Height | 18 mm / 0.709 inch |
| Height from the surface | 14.4 mm / 0.567 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Male locking latch |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 12 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 26 (picoMAX) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin diameter | 1.4 мм |
| Solder pin length | 3.6 мм |
| Total number of potentials | 12 |
| Вес | 6.92 г |
| Ширина | 62.2 mm / 2.449 inch |
Серия: 2092 (100 из 338)
- 2092-1403/205-000 2092-1404 2092-1404/005-000 2092-1404/200-000 2092-1404/205-000 2092-1405 2092-1405/005-000 2092-1405/200-000 2092-1405/205-000 2092-1406 2092-1406/005-000 2092-1406/200-000 2092-1407 2092-1408 2092-1408/005-000 2092-1408/200-000 2092-1409 2092-1410 2092-1410/005-000 2092-1410/200-000 2092-1412 2092-1412/005-000 2092-1412/200-000 2092-1422 2092-1422/005-000 2092-1422/200-000 2092-1422/205-000 2092-1423 2092-1423/005-000 2092-1423/200-000 2092-1423/205-000 2092-1424 2092-1424/005-000 2092-1424/200-000 2092-1424/205-000 2092-1425 2092-1425/005-000 2092-1425/200-000 2092-1425/205-000 2092-1426 2092-1426/005-000 2092-1426/200-000 2092-1427 2092-1428 2092-1428/005-000 2092-1428/200-000 2092-1429 2092-1430 2092-1430/005-000 2092-1430/200-000 2092-1432 2092-1432/005-000 2092-1432/200-000 2092-1502/002-000 2092-1503/002-000 2092-1504/002-000 2092-1505/002-000 2092-1506/002-000 2092-1522/002-000 2092-1522/020-000 2092-1523/002-000 2092-1523/020-000 2092-1524/002-000 2092-1524/020-000 2092-1525/002-000 2092-1525/020-000 2092-1526/002-000 2092-1526/020-000 2092-1600 2092-1600/002-000 2092-1601 2092-1601/002-000 2092-1602 2092-1602/002-000 2092-1603 2092-1603/002-000 2092-1610 2092-1630 2092-1632/024-000 2092-1633/024-000 2092-1634/024-000 2092-1635/024-000 2092-1636/024-000 2092-3102 2092-3102/002-000 2092-3102/002-1000 2092-3103 2092-3103/002-000 2092-3103/002-1000 2092-3104 2092-3104/002-000 2092-3105 2092-3105/002-000 2092-3105/002-1000 2092-3122 2092-3123 2092-3124 2092-3125 2092-3152 2092-3153
20921432, 2092 1432
