Datasheet Wago 2092-1634/024-000 — Даташит
Серия2092
Модель2092-1634/024-000
Panel feedthrough male connector; зажимное кольцо; Шаг контактов 5 мм; 4-пол.
2092-1634/024-000
Цветlight gray
Connector connection typefor pluggable connectors
Contact platingtin-plated
Country of originDE
Габариты: глубина33.4 mm / 1.315 inch
Fire load0.092 MJ
GTIN4050821165729
Height14.4 mm / 0.567 inch
Locking of plug-in connectionMale locking latch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles4
Number of levels1
Pin spacing5 mm (0.197 inch)
Product Group26 (picoMAX)
Rated current16 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)250 В
Total number of potentials4
Type of mountingFeed-through mounting Panel mounting
Вес4.23 г
Ширина34.2 mm / 1.346 inch
20921634/024000, 2092 1634/024 000
На английском языке: Datasheet Wago 2092-1634/024-000
