Datasheet Wago 2092-3175 — Даташит
1-conductor THT female header; 1.4 mm Ø solder pin; прямые; 2,5 мм²; Шаг контактов 7,5 мм; 5-пол.
| 1-CONDUCTOR THR FEMALE HEADER; 1 | |||
| 2092-3175/200-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Conductor entry angle to the PCB | 90 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 13.4 mm / 0.528 inch |
| Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.155 MJ |
| GTIN | 4050821165293 |
| Height | 16.2 mm / 0.638 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 5 |
| Number of connection types | 1 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 26 (picoMAX) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 400 В |
| Solder pin diameter | 1.4 мм |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 5 |
| Total number of potentials | 5 |
| Вес | 7.146 г |
| Ширина | 35 mm / 1.378 inch |
Серия: 2092 (100 из 338)
- 2092-1522/002-000 2092-1522/020-000 2092-1523/002-000 2092-1523/020-000 2092-1524/002-000 2092-1524/020-000 2092-1525/002-000 2092-1525/020-000 2092-1526/002-000 2092-1526/020-000 2092-1600 2092-1600/002-000 2092-1601 2092-1601/002-000 2092-1602 2092-1602/002-000 2092-1603 2092-1603/002-000 2092-1610 2092-1630 2092-1632/024-000 2092-1633/024-000 2092-1634/024-000 2092-1635/024-000 2092-1636/024-000 2092-3102 2092-3102/002-000 2092-3102/002-1000 2092-3103 2092-3103/002-000 2092-3103/002-1000 2092-3104 2092-3104/002-000 2092-3105 2092-3105/002-000 2092-3105/002-1000 2092-3122 2092-3123 2092-3124 2092-3125 2092-3152 2092-3153 2092-3154 2092-3155 2092-3172 2092-3172/200-000 2092-3173 2092-3173/200-000 2092-3174 2092-3174/200-000 2092-3175 2092-3175/200-000 2092-3302 2092-3302/200-000 2092-3303 2092-3303/200-000 2092-3304 2092-3304/200-000 2092-3305 2092-3305/200-000 2092-3322 2092-3322/200-000 2092-3323 2092-3323/200-000 2092-3324 2092-3324/200-000 2092-3325 2092-3352 2092-3353 2092-3354 2092-3355 2092-3372 2092-3373 2092-3374 2092-3375 2092-3402 2092-3402/005-000 2092-3402/200-000 2092-3402/205-000 2092-3403 2092-3403/005-000 2092-3403/200-000 2092-3403/205-000 2092-3404 2092-3404/005-000 2092-3404/200-000 2092-3404/205-000 2092-3405 2092-3405/005-000 2092-3405/200-000 2092-3405/205-000 2092-3422 2092-3422/005-000 2092-3422/200-000 2092-3422/205-000 2092-3423 2092-3423/005-000 2092-3423/200-000 2092-3423/205-000 2092-3424
20923175, 2092 3175
