Datasheet Wago 2092-3402/205-000 — Даташит
Серия2092
Модель2092-3402/205-000
Вилка THT; 1.4 mm Ø solder pin; прямые; зажимное кольцо; Шаг контактов 7,5 мм; 2-пол.
THT MALE HEADER1.4 MM SOLDER PIN STRAIGHT, LIGHT GRAY
2092-3402/205-000
2092-3402/205-000
Цветlight gray
Contact platingtin-plated
Country of originDE
Габариты: глубина14.4 mm / 0.567 inch
Fire load0.053 MJ
GTIN4050821396598
Height21.9 mm / 0.862 inch
Height from the surface19.5 mm / 0.768 inch
Locking of plug-in connectionMale locking latch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles2
Number of levels1
PCB contactTHR
Pin spacing7.5 mm (0.295 inch)
Plated through-hole diameter (THR)1.6 (+ 0.1) мм
Rated current16 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)400 В
Solder pin diameter1.4 мм
Solder pin length2.4 мм
Total number of potentials2
Type of mountingFeed-through mounting Panel mounting
Вес2.15 г
Ширина26.7 mm / 1.051 inch
20923402/205000, 2092 3402/205 000
На английском языке: Datasheet Wago 2092-3402/205-000
