Datasheet Wago 2092-3423/205-000 — Даташит
Серия2092
Модель2092-3423/205-000
Вилка THT; 1.4 mm Ø solder pin; угловые; зажимное кольцо; Шаг контактов 7,5 мм; 3-пол.
2092-3423/205-000
Цветlight gray
Contact platingtin-plated
Country of originDE
Габариты: глубина19.5 mm / 0.768 inch
Fire load0.066 MJ
GTIN4050821396642
Height16.8 mm / 0.661 inch
Height from the surface14.4 mm / 0.567 inch
Locking of plug-in connectionMale locking latch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles3
Number of levels1
PCB contactTHR
Pin spacing7.5 mm (0.295 inch)
Plated through-hole diameter (THR)1.6 (+ 0.1) мм
Rated current16 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)400 В
Solder pin diameter1.4 мм
Solder pin length2.4 мм
Total number of potentials3
Type of mountingFeed-through mounting Panel mounting
Вес2.84 г
Ширина34.2 mm / 1.346 inch
20923423/205000, 2092 3423/205 000
На английском языке: Datasheet Wago 2092-3423/205-000
