Datasheet Wago 2231-112/102-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; со встроенной торцевой пластиной; 2,5 мм²; Шаг контактов 5 мм; 12-пол.
1-CONDUCTOR FEMALE PLUG; PUSH-BU | |||
| 2231-112/102-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 25.6 mm / 1.008 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.382 MJ |
| GTIN | 4045454907723 |
| Height | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Plugging without loss of pin spacing | 1 |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 12 |
| Вес | 18.676 г |
| Ширина | 60 mm / 2.362 inch |
Серия: 2231 (100 из 343)
- 2231-103/026-000/133-000 2231-103/031-000 2231-103/037-000 2231-103/102-000 2231-104/008-000 2231-104/026-000 2231-104/031-000 2231-104/037-000 2231-104/102-000 2231-105/008-000 2231-105/026-000 2231-105/026-000/134-000 2231-105/031-000 2231-105/037-000 2231-105/037-000/134-000 2231-105/102-000 2231-106/008-000 2231-106/026-000 2231-106/031-000 2231-106/037-000 2231-106/102-000 2231-107/008-000 2231-107/026-000 2231-107/031-000 2231-107/037-000 2231-107/102-000 2231-108/008-000 2231-108/026-000 2231-108/031-000 2231-108/037-000 2231-108/102-000 2231-109/008-000 2231-109/026-000 2231-109/031-000 2231-109/037-000 2231-109/102-000 2231-110/008-000 2231-110/026-000 2231-110/031-000 2231-110/037-000 2231-110/102-000 2231-111/008-000 2231-111/026-000 2231-111/031-000 2231-111/037-000 2231-111/102-000 2231-112/008-000 2231-112/026-000 2231-112/031-000 2231-112/037-000 2231-112/102-000 2231-113/008-000 2231-113/026-000 2231-113/031-000 2231-113/037-000 2231-113/102-000 2231-114/008-000 2231-114/026-000 2231-114/031-000 2231-114/037-000 2231-114/102-000 2231-115/008-000 2231-115/026-000 2231-115/031-000 2231-115/037-000 2231-115/102-000 2231-116/008-000 2231-116/026-000 2231-116/031-000 2231-116/037-000 2231-116/102-000 2231-117/008-000 2231-117/026-000 2231-117/031-000 2231-117/037-000 2231-117/102-000 2231-118/008-000 2231-118/026-000 2231-118/031-000 2231-118/037-000 2231-118/102-000 2231-119/008-000 2231-119/026-000 2231-119/031-000 2231-119/037-000 2231-119/102-000 2231-120/008-000 2231-120/026-000 2231-120/031-000 2231-120/037-000 2231-120/102-000 2231-121/008-000 2231-121/026-000 2231-121/031-000 2231-121/037-000 2231-121/102-000 2231-122/008-000 2231-122/026-000 2231-122/031-000 2231-122/037-000
2231112/102000, 2231 112/102 000
