Datasheet Wago 2231-119/031-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; зажимное кольцо; 2,5 мм²; Шаг контактов 5 мм; 19-пол.
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 25.6 mm / 1.008 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.636 MJ |
| GTIN | 4045454877224 |
| Height | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 19 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 19 |
| Total number of potentials | 19 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 31.395 г |
| Ширина | 109.8 mm / 4.323 inch |
Серия: 2231 (100 из 343)
- 2231-109/031-000 2231-109/037-000 2231-109/102-000 2231-110/008-000 2231-110/026-000 2231-110/031-000 2231-110/037-000 2231-110/102-000 2231-111/008-000 2231-111/026-000 2231-111/031-000 2231-111/037-000 2231-111/102-000 2231-112/008-000 2231-112/026-000 2231-112/031-000 2231-112/037-000 2231-112/102-000 2231-113/008-000 2231-113/026-000 2231-113/031-000 2231-113/037-000 2231-113/102-000 2231-114/008-000 2231-114/026-000 2231-114/031-000 2231-114/037-000 2231-114/102-000 2231-115/008-000 2231-115/026-000 2231-115/031-000 2231-115/037-000 2231-115/102-000 2231-116/008-000 2231-116/026-000 2231-116/031-000 2231-116/037-000 2231-116/102-000 2231-117/008-000 2231-117/026-000 2231-117/031-000 2231-117/037-000 2231-117/102-000 2231-118/008-000 2231-118/026-000 2231-118/031-000 2231-118/037-000 2231-118/102-000 2231-119/008-000 2231-119/026-000 2231-119/031-000 2231-119/037-000 2231-119/102-000 2231-120/008-000 2231-120/026-000 2231-120/031-000 2231-120/037-000 2231-120/102-000 2231-121/008-000 2231-121/026-000 2231-121/031-000 2231-121/037-000 2231-121/102-000 2231-122/008-000 2231-122/026-000 2231-122/031-000 2231-122/037-000 2231-122/102-000 2231-123/008-000 2231-123/026-000 2231-123/031-000 2231-123/037-000 2231-123/102-000 2231-124/008-000 2231-124/026-000 2231-124/031-000 2231-124/037-000 2231-124/102-000 2231-202/008-000 2231-202/026-000 2231-202/031-000 2231-202/037-000 2231-203/008-000 2231-203/026-000 2231-203/031-000 2231-203/037-000 2231-204/008-000 2231-204/026-000 2231-204/031-000 2231-204/037-000 2231-205/008-000 2231-205/026-000 2231-205/031-000 2231-205/037-000 2231-206/008-000 2231-206/026-000 2231-206/031-000 2231-206/037-000 2231-207/008-000 2231-207/026-000
2231119/031000, 2231 119/031 000
