Datasheet Wago 2231-210/037-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 7,5 мм; 10-пол.
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 29.8 mm / 1.173 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.478 MJ |
| GTIN | 4045454810665 |
| Height | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Вес | 20.99 г |
| Ширина | 89.2 mm / 3.512 inch |
Серия: 2231 (100 из 343)
- 2231-122/008-000 2231-122/026-000 2231-122/031-000 2231-122/037-000 2231-122/102-000 2231-123/008-000 2231-123/026-000 2231-123/031-000 2231-123/037-000 2231-123/102-000 2231-124/008-000 2231-124/026-000 2231-124/031-000 2231-124/037-000 2231-124/102-000 2231-202/008-000 2231-202/026-000 2231-202/031-000 2231-202/037-000 2231-203/008-000 2231-203/026-000 2231-203/031-000 2231-203/037-000 2231-204/008-000 2231-204/026-000 2231-204/031-000 2231-204/037-000 2231-205/008-000 2231-205/026-000 2231-205/031-000 2231-205/037-000 2231-206/008-000 2231-206/026-000 2231-206/031-000 2231-206/037-000 2231-207/008-000 2231-207/026-000 2231-207/031-000 2231-207/037-000 2231-208/008-000 2231-208/026-000 2231-208/031-000 2231-208/037-000 2231-209/008-000 2231-209/026-000 2231-209/031-000 2231-209/037-000 2231-210/008-000 2231-210/026-000 2231-210/031-000 2231-210/037-000 2231-211/008-000 2231-211/026-000 2231-211/031-000 2231-211/037-000 2231-212/008-000 2231-212/026-000 2231-212/031-000 2231-212/037-000 2231-213/008-000 2231-213/026-000 2231-213/031-000 2231-213/037-000 2231-216/008-000 2231-216/026-000 2231-216/031-000 2231-216/037-000 2231-302/008-000 2231-302/026-000 2231-302/031-000 2231-302/037-000 2231-302/102-000 2231-302/107-000 2231-303/008-000 2231-303/026-000 2231-303/031-000 2231-303/037-000 2231-303/102-000 2231-303/107-000 2231-304/008-000 2231-304/026-000 2231-304/031-000 2231-304/037-000 2231-304/102-000 2231-304/107-000 2231-305/008-000 2231-305/026-000 2231-305/031-000 2231-305/037-000 2231-305/102-000 2231-305/107-000 2231-306/008-000 2231-306/026-000 2231-306/031-000 2231-306/037-000 2231-306/102-000 2231-306/107-000 2231-307/008-000 2231-307/026-000 2231-307/031-000
2231210/037000, 2231 210/037 000
