Datasheet Wago 2231-304/037-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 5,08 мм; 4-пол.
1-CONDUCTOR FEMALE PLUG; PUSH-BU | |||
| 2231-304/037-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 29.8 mm / 1.173 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.178 MJ |
| GTIN | 4045454873493 |
| Height | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 4 |
| Total number of potentials | 4 |
| Вес | 7.942 г |
| Ширина | 37.02 mm / 1.457 inch |
Серия: 2231 (100 из 343)
- 2231-206/026-000 2231-206/031-000 2231-206/037-000 2231-207/008-000 2231-207/026-000 2231-207/031-000 2231-207/037-000 2231-208/008-000 2231-208/026-000 2231-208/031-000 2231-208/037-000 2231-209/008-000 2231-209/026-000 2231-209/031-000 2231-209/037-000 2231-210/008-000 2231-210/026-000 2231-210/031-000 2231-210/037-000 2231-211/008-000 2231-211/026-000 2231-211/031-000 2231-211/037-000 2231-212/008-000 2231-212/026-000 2231-212/031-000 2231-212/037-000 2231-213/008-000 2231-213/026-000 2231-213/031-000 2231-213/037-000 2231-216/008-000 2231-216/026-000 2231-216/031-000 2231-216/037-000 2231-302/008-000 2231-302/026-000 2231-302/031-000 2231-302/037-000 2231-302/102-000 2231-302/107-000 2231-303/008-000 2231-303/026-000 2231-303/031-000 2231-303/037-000 2231-303/102-000 2231-303/107-000 2231-304/008-000 2231-304/026-000 2231-304/031-000 2231-304/037-000 2231-304/102-000 2231-304/107-000 2231-305/008-000 2231-305/026-000 2231-305/031-000 2231-305/037-000 2231-305/102-000 2231-305/107-000 2231-306/008-000 2231-306/026-000 2231-306/031-000 2231-306/037-000 2231-306/102-000 2231-306/107-000 2231-307/008-000 2231-307/026-000 2231-307/031-000 2231-307/037-000 2231-307/102-000 2231-307/107-000 2231-308/008-000 2231-308/026-000 2231-308/031-000 2231-308/037-000 2231-308/102-000 2231-308/107-000 2231-309/008-000 2231-309/026-000 2231-309/031-000 2231-309/037-000 2231-309/102-000 2231-309/107-000 2231-310/008-000 2231-310/026-000 2231-310/031-000 2231-310/037-000 2231-310/102-000 2231-310/107-000 2231-311/008-000 2231-311/026-000 2231-311/031-000 2231-311/037-000 2231-311/102-000 2231-312/008-000 2231-312/026-000 2231-312/031-000 2231-312/037-000 2231-312/102-000 2231-312/107-000
2231304/037000, 2231 304/037 000
