Datasheet Wago 2231-313/008-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; Монтажные ножки; 2,5 мм²; Шаг контактов 5,08 мм; 13-пол.
1-CONDUCTOR FEMALE PLUG; PUSH-BU | |||
| 2231-313/037-000 Wago | по запросу | ||
| 2231-313/026-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 25.6 mm / 1.008 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.435 MJ |
| GTIN | 4045454724399 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 19.5 mm / 0.768 inch |
| Height from the surface | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 13 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 13 |
| Total number of potentials | 13 |
| Type of mounting | Panel mounting |
| Вес | 20.994 г |
| Ширина | 67.54 mm / 2.659 inch |
Серия: 2231 (100 из 343)
- 2231-304/037-000 2231-304/102-000 2231-304/107-000 2231-305/008-000 2231-305/026-000 2231-305/031-000 2231-305/037-000 2231-305/102-000 2231-305/107-000 2231-306/008-000 2231-306/026-000 2231-306/031-000 2231-306/037-000 2231-306/102-000 2231-306/107-000 2231-307/008-000 2231-307/026-000 2231-307/031-000 2231-307/037-000 2231-307/102-000 2231-307/107-000 2231-308/008-000 2231-308/026-000 2231-308/031-000 2231-308/037-000 2231-308/102-000 2231-308/107-000 2231-309/008-000 2231-309/026-000 2231-309/031-000 2231-309/037-000 2231-309/102-000 2231-309/107-000 2231-310/008-000 2231-310/026-000 2231-310/031-000 2231-310/037-000 2231-310/102-000 2231-310/107-000 2231-311/008-000 2231-311/026-000 2231-311/031-000 2231-311/037-000 2231-311/102-000 2231-312/008-000 2231-312/026-000 2231-312/031-000 2231-312/037-000 2231-312/102-000 2231-312/107-000 2231-313/008-000 2231-313/026-000 2231-313/031-000 2231-313/037-000 2231-313/102-000 2231-314/008-000 2231-314/026-000 2231-314/031-000 2231-314/037-000 2231-314/102-000 2231-314/107-000 2231-315/008-000 2231-315/026-000 2231-315/031-000 2231-315/037-000 2231-315/102-000 2231-315/107-000 2231-316/008-000 2231-316/026-000 2231-316/031-000 2231-316/037-000 2231-316/102-000 2231-316/107-000 2231-317/008-000 2231-317/026-000 2231-317/031-000 2231-317/037-000 2231-317/102-000 2231-318/008-000 2231-318/026-000 2231-318/031-000 2231-318/037-000 2231-318/102-000 2231-319/008-000 2231-319/026-000 2231-319/031-000 2231-319/037-000 2231-319/102-000 2231-320/008-000 2231-320/026-000 2231-320/031-000 2231-320/037-000 2231-320/102-000 2231-321/008-000 2231-321/026-000 2231-321/031-000 2231-321/037-000 2231-321/102-000 2231-322/008-000 2231-322/026-000
2231313/008000, 2231 313/008 000
