Datasheet Wago 2231-702/031-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; зажимное кольцо; 2,5 мм²; Шаг контактов 7,62 мм; 2-пол.
Modular Probe Banana Tip For Hand Held DMM | |||
| 2231-702/008-000 Wago | по запросу | ||
| 6304-223-1702 | по запросу | ||
| 6304-223-1702 Pomona Electronics | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 25.6 mm / 1.008 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.105 MJ |
| GTIN | 4045454811785 |
| Height | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.62 mm (0.3 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 4.476 г |
| Ширина | 27.42 mm / 1.08 inch |
Серия: 2231 (100 из 343)
- 2231-314/037-000 2231-314/102-000 2231-314/107-000 2231-315/008-000 2231-315/026-000 2231-315/031-000 2231-315/037-000 2231-315/102-000 2231-315/107-000 2231-316/008-000 2231-316/026-000 2231-316/031-000 2231-316/037-000 2231-316/102-000 2231-316/107-000 2231-317/008-000 2231-317/026-000 2231-317/031-000 2231-317/037-000 2231-317/102-000 2231-318/008-000 2231-318/026-000 2231-318/031-000 2231-318/037-000 2231-318/102-000 2231-319/008-000 2231-319/026-000 2231-319/031-000 2231-319/037-000 2231-319/102-000 2231-320/008-000 2231-320/026-000 2231-320/031-000 2231-320/037-000 2231-320/102-000 2231-321/008-000 2231-321/026-000 2231-321/031-000 2231-321/037-000 2231-321/102-000 2231-322/008-000 2231-322/026-000 2231-322/031-000 2231-322/037-000 2231-322/102-000 2231-323/008-000 2231-323/026-000 2231-323/031-000 2231-323/037-000 2231-323/102-000 2231-324/008-000 2231-324/026-000 2231-324/031-000 2231-324/037-000 2231-324/102-000 2231-702/008-000 2231-702/026-000 2231-702/031-000 2231-702/037-000 2231-703/008-000 2231-703/026-000 2231-703/026-000/133-000 2231-703/031-000 2231-703/037-000 2231-704/008-000 2231-704/026-000 2231-704/031-000 2231-704/037-000 2231-705/008-000 2231-705/026-000 2231-705/031-000 2231-705/037-000 2231-706/008-000 2231-706/026-000 2231-706/031-000 2231-706/037-000 2231-707/008-000 2231-707/026-000 2231-707/031-000 2231-707/037-000 2231-708/008-000 2231-708/026-000 2231-708/031-000 2231-708/037-000 2231-709/008-000 2231-709/026-000 2231-709/031-000 2231-709/037-000 2231-710/008-000 2231-710/026-000 2231-710/031-000 2231-710/037-000 2231-711/008-000 2231-711/026-000 2231-711/031-000 2231-711/037-000 2231-712/008-000 2231-712/026-000 2231-712/031-000 2231-712/037-000
2231702/031000, 2231 702/031 000
