Datasheet Wago 2604-3109 — Даташит
Клеммная колодка для печатной платы; рычаг; 4 мм²; Шаг контактов 5 мм; 9-полюсный; Зажим Push-in CAGE CLAMP
|  Купить 2604-3109 на РадиоЛоцман.Цены — от 1 397 до 3 940 ₽ 14 предложений от 4 поставщиков PCB TERMINAL BLOCK; LEVER; 4 MM; | |||
| 2604-3109 | от 1 397 ₽ | ||
| 2604-3109 Wago | от 1 598 ₽ | ||
| 2604-3109 Wago | 3 940 ₽ | ||
| 2604-3109 Wago | по запросу | ||
| Actuating element color | orange |
| Actuation type | Lever |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 90 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | DE |
| Габариты: глубина | 16.7 mm / 0.657 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 4 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 2.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fine-stranded conductor, with twin ferrule | 0.25 … 1.5 mm² |
| GTIN | 4055143564786 |
| Height | 25.3 mm / 0.996 inch |
| Height from the surface | 21.3 mm / 0.839 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 9 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Rated current | 32 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 400 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.8 x 1 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.2 … 4 mm² / 24 … 12 AWG |
| Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
| Total number of connection points | 9 |
| Total number of potentials | 9 |
| Вес | 15.03 г |
| Ширина | 47.4 mm / 1.866 inch |
Серия: 2604 (69)
- 2604-1101 2604-1102 2604-1103 2604-1104 2604-1105 2604-1106 2604-1107 2604-1108 2604-1109 2604-1110 2604-1111 2604-1112 2604-1302 2604-1303 2604-1303/000-016 2604-1304 2604-1305 2604-1306 2604-1307 2604-1308 2604-1309 2604-1310 2604-1311 2604-1312 2604-1502 2604-1503 2604-1504 2604-1505 2604-1506 2604-1507 2604-1508 2604-1509 2604-1510 2604-1511 2604-1512 2604-3101 2604-3102 2604-3103 2604-3104 2604-3105 2604-3106 2604-3107 2604-3108 2604-3109 2604-3110 2604-3111 2604-3112 2604-3302 2604-3303 2604-3304 2604-3305 2604-3306 2604-3307 2604-3308 2604-3309 2604-3310 2604-3311 2604-3312 2604-3502 2604-3503 2604-3504 2604-3505 2604-3506 2604-3507 2604-3508 2604-3509 2604-3510 2604-3511 2604-3512
- PCB Interconnect
26043109, 2604 3109
