Datasheet Wago 2606 — Даташит
| Производитель | Wago |
| Серия | 2606 |
Купить 2606-1101 на РадиоЛоцман.Цены — от 92 до 417 ₽21 предложений от 6 поставщиков PCB TERMINAL BLOCK; LEVER; 6 MM; | |||
| 2606-1101 Wago | 92 ₽ | ||
| 2606-1101 | от 308 ₽ | ||
| 2606-1101 Wago | от 412 ₽ | ||
| 2606-1101 Wago | от 417 ₽ | ||
| Parameters / Models | 2606-1101![]() | 2606-1102![]() | 2606-1102/020-000![]() | 2606-1103/010-000![]() | 2606-1103/020-000![]() | 2606-1104/010-000![]() | 2606-1104/020-000![]() | 2606-1104/020-004![]() | 2606-1105/010-000![]() | 2606-1105/020-000![]() | 2606-1105/020-015![]() | 2606-1106/010-000![]() | 2606-1106/020-000![]() | 2606-1107/020-000![]() | 2606-1108/020-000![]() | 2606-1109/020-000![]() | 2606-1110/020-000![]() | 2606-1111/020-000![]() | 2606-1112/020-000![]() | 2606-3101![]() | 2606-3102/020-000![]() | 2606-3103/020-000![]() | 2606-3104/020-000![]() | 2606-3105/020-000![]() | 2606-3106/020-000![]() | 2606-3107/020-000![]() | 2606-3108/020-000![]() | 2606-3109/020-000![]() | 2606-3110/020-000![]() | 2606-3111/020-000![]() | 2606-3112/020-000![]() |
| Actuating element color | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange | orange |
| Actuation type | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever | Lever |
| Clamping spring material | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) |
| Цвет | gray | gray | gray | gray | gray | gray | gray | black | gray | gray | gentian blue | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray |
| Conductor entry angle to the PCB, ° | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | |||||||||||||||||||
| Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) |
| Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated |
| Country of origin | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE |
| Габариты: глубина | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24.3 mm / 0.957 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch |
| Drilled hole diameter (tolerance), мм | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) | 2(+ 0.1) |
| Fine-stranded conductor | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² | 0.25 … 6 mm² |
| Fine-stranded conductor, with twin ferrule | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² |
| Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 |
| GTIN | 4055143586405 | 4055143668224 | 4055143586412 | 4055143662673 | 4055143586429 | 4055143634519 | 4055143586436 | 4055143639101 | 4055143634540 | 4055143586443 | 4055143640947 | 4055143634557 | 4055143586450 | 4055143586467 | 4055143586474 | 4055143586481 | 4055143586542 | 4055143586559 | 4055143586566 | 4055143586580 | 4055143586603 | 4055143586610 | 4055143586627 | 4055143586634 | 4055143586658 | 4055143586672 | 4055143586689 | 4055143586696 | 4055143586702 | 4055143586719 | 4055143586726 |
| Height | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 28 mm / 1.102 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch | 31 mm / 1.22 inch |
| Height from the surface | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 24 mm / 0.945 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch | 27 mm / 1.063 inch |
| Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
| Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 |
| Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C |
| Material group | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I |
| Number of Poles | 1 | 2 | 2 | 3 | 3 | 4 | 4 | 4 | 5 | 5 | 5 | 6 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Number of connection types | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Number of solder pins per potential | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| PCB contact | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT |
| Pin spacing | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) |
| Rated current, A | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 | 41 |
| Rated impulse voltage (II / 2), kV | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Rated impulse voltage (III / 2), kV | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Rated impulse voltage (III / 3), kV | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Rated voltage (II / 2), В | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
| Rated voltage (III / 2), В | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
| Rated voltage (III / 3), В | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 | 800 |
| Solder pin arrangement | within the terminal block, in line | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | within the terminal block, in line | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered |
| Solder pin dimensions | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm | 1.5 x 1.2 mm |
| Solder pin length, мм | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Solid conductor | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG | 0.2 … 10 mm² / 24 … 8 AWG |
| Strip length | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch |
| Total number of connection points | 1 | 2 | 2 | 3 | 4 | 4 | 4 | 5 | 5 | 5 | 6 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | |
| Total number of potentials | 1 | 2 | 2 | 3 | 3 | 4 | 4 | 4 | 5 | 5 | 5 | 6 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Вес, г | 4.421 | 8.411 | 8.028 | 11.871 | 11.748 | 15.785 | 15.485 | 15.824 | 19.602 | 19.205 | 19.711 | 23.392 | 22.942 | 26.662 | 30.399 | 34.119 | 37.856 | 41.576 | 45.313 | 5.04 | 8.858 | 13.037 | 17.056 | 21.235 | 25.254 | 29.433 | 33.452 | 37.631 | 41.65 | 45.829 | 49.848 |
| Ширина | 10.35 mm / 0.407 inch | 17.85 mm / 0.703 inch | 17.85 mm / 0.703 inch | 25.35 mm / 0.998 inch | 25.35 mm / 0.998 inch | 32.85 mm / 1.293 inch | 32.85 mm / 1.293 inch | 32.85 mm / 1.293 inch | 40.35 mm / 1.589 inch | 40.35 mm / 1.589 inch | 40.35 mm / 1.589 inch | 47.85 mm / 1.884 inch | 47.85 mm / 1.884 inch | 55.35 mm / 2.179 inch | 62.85 mm / 2.474 inch | 70.35 mm / 2.77 inch | 77.85 mm / 3.065 inch | 85.35 mm / 3.36 inch | 92.85 mm / 3.656 inch | 10.35 mm / 0.407 inch | 17.85 mm / 0.703 inch | 25.35 mm / 0.998 inch | 32.85 mm / 1.293 inch | 40.35 mm / 1.589 inch | 47.85 mm / 1.884 inch | 55.35 mm / 2.179 inch | 62.85 mm / 2.474 inch | 70.35 mm / 2.77 inch | 77.85 mm / 3.065 inch | 85.35 mm / 3.36 inch | 92.85 mm / 3.656 inch |
Серия: 2606 (31)
- 2606-1101 2606-1102 2606-1102/020-000 2606-1103/010-000 2606-1103/020-000 2606-1104/010-000 2606-1104/020-000 2606-1104/020-004 2606-1105/010-000 2606-1105/020-000 2606-1105/020-015 2606-1106/010-000 2606-1106/020-000 2606-1107/020-000 2606-1108/020-000 2606-1109/020-000 2606-1110/020-000 2606-1111/020-000 2606-1112/020-000 2606-3101 2606-3102/020-000 2606-3103/020-000 2606-3104/020-000 2606-3105/020-000 2606-3106/020-000 2606-3107/020-000 2606-3108/020-000 2606-3109/020-000 2606-3110/020-000 2606-3111/020-000 2606-3112/020-000
- PCB Interconnect
