Datasheet Wago 2606-1106/010-000 — Даташит
Клеммная колодка для печатной платы; рычаг; 6 мм²; Шаг контактов 7,5 мм; 6-полюсный; Зажим Push-in CAGE CLAMP
2606-1106/010-000 Wago | 693 ₽ |
Actuating element color | orange |
Actuation type | Lever |
Цвет | gray |
Country of origin | DE |
Габариты: глубина | 24.3 mm / 0.957 inch |
Drilled hole diameter (tolerance) | 2(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 10 mm² / 24 … 8 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 6 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 6 mm² |
Fine-stranded conductor, with twin ferrule | 0.25 … 2.5 mm² |
GTIN | 4055143634557 |
Height | 28 mm / 1.102 inch |
Height from the surface | 24 mm / 0.945 inch |
Material group | I |
Number of Poles | 6 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 41 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 800 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 1.5 x 1.2 mm |
Solder pin length | 4 мм |
Solid conductor | 0.2 … 10 mm² / 24 … 8 AWG |
Strip length | 11 … 13 mm / 0.43 … 0.51 Inch |
Total number of connection points | 6 |
Total number of potentials | 6 |
Вес | 23.392 г |
Ширина | 47.85 mm / 1.884 inch |
Серия: 2606 (31)
- 2606-1101 2606-1102 2606-1102/020-000 2606-1103/010-000 2606-1103/020-000 2606-1104/010-000 2606-1104/020-000 2606-1104/020-004 2606-1105/010-000 2606-1105/020-000 2606-1105/020-015 2606-1106/010-000 2606-1106/020-000 2606-1107/020-000 2606-1108/020-000 2606-1109/020-000 2606-1110/020-000 2606-1111/020-000 2606-1112/020-000 2606-3101 2606-3102/020-000 2606-3103/020-000 2606-3104/020-000 2606-3105/020-000 2606-3106/020-000 2606-3107/020-000 2606-3108/020-000 2606-3109/020-000 2606-3110/020-000 2606-3111/020-000 2606-3112/020-000
- PCB Interconnect
26061106/010000, 2606 1106/010 000
